这是AutoCAD的问题
根据已知条件我可以得到如下条件 圆弧的两点,起始角和终止角
条件是圆弧上两点x1,y1 x2,y2 ,alfa1,alfa2
求 圆心坐标xc,yc和半径的算法比较麻烦.
变通方法
Sub msl()
'tt = "(command " & Chr(34) & "arc" & Chr(34) & " pp " & Chr(34) & "e" & Chr(34) & " ppp " & Chr(34) & "a" & Chr(34) & " 152) "
tt = "(command " & Chr(34) & "arc" & Chr(34) & "(list -9.24 14.04 0)" & Chr(34) & "e" & Chr(34) & "(list -4.62 14.04 0) " & Chr(34) & "a" & Chr(34) & " " & 1.967808816 * 180 / 3.1415926 & ") "
ThisDrawing.SendCommand tt
End Sub
下面程序各位大侠拿去用,比较实用. - Sub DrawingArc()
- nn = ThisDrawing.ModelSpace.Count - 1
- Dim objArc As AcadArc, objLine As AcadLine
- With ThisDrawing.ModelSpace
- For ii = 0 To nn
- 'Debug.Print .Item(ii).ObjectName
- Select Case .Item(ii).ObjectName
- Case "AcDbLine"
- Case "AcDbArc"
- Set objArc = .Item(ii)
- tt = "(command " & Chr(34) & "arc" & Chr(34) & "(list"
- For jj = 0 To 2
- tt = tt & " " & Round(objArc.StartPoint(jj), 2)
- Next jj
- tt = tt & ")" & Chr(34) & "e" & Chr(34) & "(list"
- For jj = 0 To 2
- tt = tt & " " & Round(objArc.EndPoint(jj), 2)
- Next jj
- tt = tt & ") " & Chr(34) & "a" & Chr(34) & " " & objArc.TotalAngle * 180 / 3.1415926 & ") "
- Debug.Print tt
- ThisDrawing.SendCommand tt
- End Select
- Next ii
- End With
- End Sub
