查看: 2126|回复: 6
各位,帮忙看看程序错在哪里?
发表于 2003-5-28 10:59:00 | 显示全部楼层 |阅读模式
dcl文件:
gear:dialog {
label="齿数";
:edit_box {
label="输入齿数";
key="mun";
edit_width=8;
:popup_list {
label="模数";
key="mod";
edit_width=8;
:edit_box {
label="厚度";
key="hight";
edit_width=9;
:edit_box {
label="小圆半径";
key="d";
edit_width=9;
ok_button;
程序:
;               输入数据
(defun input ()
        (setq p1        (getpoint         "\n输入齿轮的中心点:"))
        (setq n1         (GET_TILE       "mun")
              n         (atoi n1))
        (setq mod1        (GET_TILE        "mod")
              mod       (atoi mod1))
        (setq gh1        (GET_TILE        "hight")
              gh        (atoi gh1))
        (setq d11        (GET_TILE       "d")
              d1        (atoi d11))
(defun calculating1 ()
;主程序
(defun c:gear ()
        (setq it_dcl (load_dialog "gear.dcl"))
        (if (< it_dcl 0)
    (exit)
        (if (not (new_dialog "gear" it_dcl))
    (exit)
      (start_list "mod")
      (setq modshu '("1" "1.25" "1.5" "2" "2.5" "3" "4" "5" "6" "8" "10" "12" "16" "20" "25" "32" "40" "50"))
      (mapcar 'add_list modshu)
      (end_list)
      (action_tile "accept" "(input)(done_dialog)"
      (start_dialog)
        (input)
        (calculating1)
        (prompt "\n输入gear运行程序"))
输入后反馈:
error: bad argument type: stringp nil
 楼主| 发表于 2003-5-28 11:53:00 | 显示全部楼层
那就是说怎样可以取到dcl文件中的数据。
发表于 2003-5-28 12:26:00 | 显示全部楼层
错误原因在于括号
语句(action_tile "accept" "(input)(done_dialog)" 最后少了")",
语句(prompt "\n输入gear运行程序")) 最后多了")"
 楼主| 发表于 2003-5-28 13:08:00 | 显示全部楼层
我修改好了,但是也有同样的错误,怎么办?
 楼主| 发表于 2003-5-28 13:12:00 | 显示全部楼层
同样
也就是
dcl文件:
a:dialog {
label="齿数";
:popup_list {
label="模数";
key="mod";
edit_width=8;
ok_button;
lisp文件:
(defun c:a()
   (setq it_dcl (load_dialog "a.dcl"))
        (if (< it_dcl 0)
    (exit)
        (if (not (new_dialog "a" it_dcl))
    (exit)
      (start_list "mod")
      (end_list)
  (action_tile "accept" "(input)(done_dialog)")
      (start_dialog)
              mod       (atoi mod1))
    (princ mod)
也有同样错误,
怎么办啊,急~~
发表于 2003-5-28 16:40:00 | 显示全部楼层
未仔细调试,看错误提示,应该是在INPUT函数中,GET_TILE有些未从对话框中取得正确
未仔细调试,看错误提示,应该是在INPUT函数中,GET_TILE有些未从对话框中取得正确值[br]
发表于 2003-6-3 17:16:00 | 显示全部楼层
check
(defun input ()
        n  (atoi n1)
        mod  (atoi mod1)
        gh  (atoi gh1)
        d1  (atoi d11)
                                        ;主程序
(defun c:gear ()
  (setq it_dcl (load_dialog (findfile "gear.dcl")))
  (if (< it_dcl 0)
    (exit)
    (exit)
  (start_list "mod")
                 "25"        "32"   "40"   "50"
  (end_list)
  (action_tile
    "accept"
    (start_dialog)
    (input)
    (calculating1)
GMT+8, 2025-4-5 05:28 , Processed in 0.183885 second(s), 27 queries , Gzip On.
