查看: 817|回复: 1
求助
发表于 2008-10-6 09:36:00 | 显示全部楼层 |阅读模式
我用以下VBA编程:
Sub 画点编程()
Dim startPoint(0 To 2) As Double
Dim OjtPoint As AcadPoint
startPoint(0) = 100 'X
startPoint(1) = 10000 'Y
startPoint(2) = 0 'Z
Set OjtPoint = ACADProject.ThisDrawing.ModelSpace.AddPoint(startPoint)
End Sub
我已置我的用户坐标为当前坐标,但结果却是画点仍以世界坐标值画.我买了一本《AutoCAD VBA二次开发教程》看,但从中未找到启发,请高手百忙中指点一下好吗?以上编程语言,要作什么修改才可以是以UCS坐标画点呢?
 楼主| 发表于 2008-10-6 14:05:00 | 显示全部楼层
' 将点的UCS坐标转化到WCS坐标
Private Function PtUcs2Wcs(ptUcs As Variant) As Variant
    PtUcs2Wcs = ThisDrawing.Utility.TranslateCoordinates(ptUcs, acUCS, acWorld, False)
End Function
Sub 画点编程081007()
'Dim ptStart As Variant
'Dim ptEnd As Variant
Dim ptStart(0 To 2) As Double
Dim ptEnd(0 To 2) As Double
ptStart(0) = 0 ''40''X
ptStart(1) = 100 ''Y
ptStart(2) = 0 '400'''Z
Dim ptStUcs As Variant
ptStUcs = PtUcs2Wcs(ptStart)
Set OjtPoint = ThisDrawing.ModelSpace.AddPoint(ptStUcs)
End Sub
GMT+8, 2025-5-1 02:59 , Processed in 0.147083 second(s), 25 queries , Gzip On.
