查看: 1350|回复: 1
[求助]VBA编缉的菜单加载程序在04中成功,而06中失败了,请高手指教
发表于 2008-10-15 13:17:00 | 显示全部楼层 |阅读模式
      用VBA编缉的菜单加载程序,就是在菜单的最后增加一个菜单项,在04中加载成功了,但在06中,不但未成功,原来的菜单项还少了许多。简单代码如下:
Public Sub acad()
'为工程创建下拉菜单
Dim newmenugroup As AcadMenuGroup
Dim newmenu As AcadPopupMenu
Dim submenu1(10) As AcadPopupMenuItem
Dim newmenuitem(10) As AcadPopupMenu
Dim macrostr(10) As String
'定义下拉菜单群组
Set newmenugroup = ThisDrawing.Application.MenuGroups.Item(0)
'创建新下拉菜单
Set newmenu = newmenugroup.Menus.Add("W M C" + Chr(Asc("&")) + "Y")
'定义宏
macrostr(0) = Chr(3) & Chr(3) & "-vbarun" + Chr(32) + "a1" + Chr(32) '打开sawk窗口
macrostr(1) = Chr(3) & Chr(3) & "-vbarun" + Chr(32) + "a1" + Chr(32)
'创建下拉菜单
Set newmenuitem(0) = newmenu.AddSubMenu(newmenu.Count + 1, "SAW")
Set newmenuitem(1) = newmenu.AddSubMenu(newmenu.Count + 2, "SWAW")
Set newmenuitem(2) = newmenu.AddSubMenu(newmenu.Count + 3, "GMAW")
Set submenu1(0) = newmenu.Item(0).SubMenu.AddMenuItem(0, "Single Vee", macrostr(0))
Set submenu1(1) = newmenu.Item(0).SubMenu.AddMenuItem(1, "Bouble Vee", macrostr(1))
'插入下拉菜单项
newmenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
End Sub
望高手指教。
发表于 2012-3-9 14:10:48 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-5-25 12:14 , Processed in 0.162683 second(s), 23 queries , Gzip On.
