查看: 2801|回复: 12
[求助]有关批量标注圆
发表于 2008-10-15 22:24:00 | 显示全部楼层 |阅读模式
有人知道批量标注,就是图形内有多个不等直径的圆,如何一次性框选后自动标出所选对象的是半径的就标半径,是直径的就标直径
发表于 2010-6-8 12:29:00 | 显示全部楼层
(defun c:rds (/ rs n po px py rv ang1 ang2 angc cx cy rslst)
  (setq rs (ssget))
  (if rs
      (setq n 0)
      (repeat (sslength rs)
 (setq rslst (entget (ssname rs n)))
 (setq po (cdr (assoc 10 rslst)));圆心
 (setq px (car po))
 (setq py (cadr po))
 (setq rv (cdr (assoc 40 rslst)));半径
 (cond
   ((= "ARC" (cdr (assoc 0 rslst)))
    (setq ang1 (cdr (assoc 50 rslst)))
    (setq ang2 (cdr (assoc 51 rslst)))
    (setq angc (/ (+ ang2 ang1) 2.0))
    (setq cx (+ px (* rv (cos angc))))
    (setq cy (+ py (* rv (sin angc))))
    (command "DIMRADIUS" (list (ssname rs n) (list cx cy 0)) "")
   ((= "CIRCLE" (cdr (assoc 0 rslst)))
    (setq angc (/ pi 4.0))
    (command "DIMDIAMETER" (list (ssname rs n ) (list cx cy 0)) "")
 (setq n (1+ n))
发表于 2012-12-6 22:26:42 | 显示全部楼层
QDIM可以实现的
发表于 2018-5-29 14:00:36 | 显示全部楼层
vla方式的标注原因,应该没有版本限制
发表于 2008-10-15 23:13:00 | 显示全部楼层
使用命令QDIM就搞定
发表于 2008-10-16 09:15:00 | 显示全部楼层
QDIM是连续标注,不是批量标圆的半径啊
 楼主| 发表于 2008-10-17 22:07:00 | 显示全部楼层
  (setq rs (ssget "c" pt1 pt2 '((0 . "circle"))))
  (if rs
      (setq n 0)
 (setq px (car po))
 (setq py (cadr po))
 (cond
    ;(command "DIMRADIUS" (list (ssname rs n) (list cx cy 0)))
;;;    (princ "\n poic is")
;;;    (princ (list cx cy))
;;;    (princ "\n")
;;;    (princ "circle")
 (setq n (1+ n))
此代码即可解决了
发表于 2010-7-5 21:35:00 | 显示全部楼层
坎坎坷坷坎坎坷坷坎坎坷坷
发表于 2010-7-6 10:22:00 | 显示全部楼层
(setq rs (ssget  '((0 . "circle,arc"))))
发表于 2011-3-29 21:27:27 | 显示全部楼层
又学到一点,谢谢了
发表于 2012-12-6 15:49:08 | 显示全部楼层
hnfsf 发表于 2010-6-8 12:29
(defun c:rds (/ rs n po px py rv ang1 ang2 angc cx cy rslst)  (setq rs (ssget))  (if rs&nb ...
能把标注的方向修改到别一边吗?如图:
发表于 2012-12-6 16:06:53 | 显示全部楼层
高版本Cad有圆的快速标注
GMT+8, 2025-9-30 05:35 , Processed in 0.197666 second(s), 29 queries , Gzip On.
