查看: 1805|回复: 4
[求助]lsp和dcl文件的问题
发表于 2008-10-22 08:54:00 | 显示全部楼层 |阅读模式
我编了lsp和dcl文件,能加载,但运行时出问题。提示“找不到对话框 ALmaoyi 的定义”,
请朋友们把我看看问题出在哪里?我把这两个文件放在 D:\Program Files\AutoCAD 2006\Support
发表于 2008-10-22 10:11:00 | 显示全部楼层
对话框标题不对啊!!
(new_dialog "ALmaoyi" dcl_id)
中的
 "ALmaoyi" 在 DCL 中没有
把 gongyi 改成 ALmaoyi
 楼主| 发表于 2008-10-22 11:06:00 | 显示全部楼层
谢谢!新手给大家搞笑话了。
发表于 2008-11-4 20:57:00 | 显示全部楼层
哦,这样真的行吗。。。。
我明天去试下。。。。
发表于 2022-6-6 22:32:00 | 显示全部楼层
;<<<<<<合并DCL和lsp文件  >>>>>>
   (setq dcl_file (open (setq tmp-dcl-file-name (vl-filename-mktemp nil nil  ".DCL")) "w"))
                 (foreach x
                     "ALmaoyi:dialog{ "
                     "label=\"艾蕾\";  "
                     ":boxed_row{  "
                     "label=\"输入密度\"; "
                     ":edit_box{  "
                     "label=\"针(cm)\"; "
                     "key=\"zm\";  "
                     "fixed_width=true; "
                     "edit_width=8; "
                     "alignment=centered; "
                     ":edit_box{"
                     "label=\"     行(cm)\";"
                     "key=\"hm\";"
                     "fixed_width=true;"
                     "edit_width=8;"
                     "alignment=centered;"
                     ":text{ "
                     "label=\"针或行的距离\";"
                     ":boxed_row{"
                     "label=\"输入已知值\";"
                     ":edit_box{"
                     "label=\"行数\";"
                     "key=\"hs\";"
                     "edit_width=4;"
                     ":edit_box{"
                     "label=\"     针数\";"
                     "key=\"zs\";"
                     "edit_width=4;"
                     ":edit_box{"
                     "label=\"     次数\";"
                     "key=\"cs\";"
                     "edit_width=4;"
                     ":toggle{  "
                     "label=\"删除源线段\";  "
                     "value=0;  "
                     ":boxed_row{"
                     ":button{"
                     "label=\"计算\";"
                     "key=\"jisuan\";"
                     "fixed_width=true;"
                     "width=5;"
                     "ok_cancel;   "
     ) (write-line x dcl_file) )
     (setq dcl_file (close dcl_file)))
(defun c:gy (/ dcl_id)
  (setq ent (entsel "\n选取线段"))
  (setq entlst (entget (car ent)))
  (setq pt1 (cdr (assoc 10 entlst)))
  (setq pt2 (cdr (assoc 11 entlst)))
  (setq dcl_id (load_dialog tmp-dcl-file-name))
  (if(not(new_dialog "ALmaoyi" dcl_id))(exit))
  (action_tile "jisuan" "(zichengxu)")      ;单击「开始」调用子程序
  (start_dialog)
  (unload_dialog dcl_id)
(defun zichengxu()      ;菜单子程序
  (setq zmz (atof (get_tile "zm")))
  (setq hmz (atof (get_tile "hm")))
  ;(setq hsz (atof (get_tile "hs")))
  ;(setq zsz (atof (get_tile "zs")))
  ;(setq csz (atof (get_tile "cs")))
  (if (= (get_tile "zs") "")
    (setq csz 1.0)
    (setq csz (atof (rtos (/ (- (car pt2) (car pt1)) (abs (atof (get_tile "zs"))) (* zmz 0.1)) 2 0)))
    (setq zsz (atof (rtos (/ (- (car pt2) (car pt1)) csz (* zmz 0.1)) 2 0)))
  (setq hsz (atof (rtos (/ (- (cadr pt2) (cadr pt1)) csz (* hmz 0.1)) 2 0)))
  (set_tile "hs" (rtos hsz 2 0))
  (set_tile "zs" (rtos zsz 2 0))
  (set_tile "cs" (rtos csz 2 0))
DCLLSP整合版
GMT+8, 2025-5-15 17:35 , Processed in 0.173507 second(s), 26 queries , Gzip On.
