查看: 1158|回复: 4
[求助]上次遗留的一个问题,高手在帮一下
发表于 2008-10-27 12:50:00 | 显示全部楼层 |阅读模式
还是这个问题,其他的解决了
在最后传回结果那一句不知怎么不对传回的是 rtos (* md cd)
我想问一下这是什么原因,高手帮忙解决一下,谢谢了
(defun c:jg()     (setq dcl_id (load_dialog "d:\\LX\\zl.dcl") chk 0)
                  (new_dialog "zl" dcl_id)
                  (addl1)
                  (action_tile "jg_l" "(addl1)")                //新增的下拉式選框元件動作
                  (action_tile "jg_l" "(setq tmp_r (atoi (get_tile \"jg_l\")))(select1)")
                  (setq cd (stof (get_tile "jg_cd"))  md (stof (get_tile "jg_md")))     //取得长度编辑框值
                  (set_tile "jg_zl" "(rtos (* md cd))")                                //计算其值
                  (START_DIALOG) (UNLOAD_DIALOG DCL_ID)
            (PRINC)
(defun addl1 ()  (setq j_id (open "d:\\LX\\jg1.txt" "r"))        //选取角钢清单表并载入清单
 (setq tmp_t (read-line j_id) tmp_l (list ""))
 (while (/= tmp_t nil)
    (setq tmp_l (append tmp_l (list tmp_t)))
    (setq tmp_l (read-line f_id))
 (close f_id)
 (setq tmp_l (list (cdr tmp_l)))
 (start_list "jg_l" 3 0)
 (mapcar 'add_list (car tmp_l))
 (end_list)
(defun select1 ()                                              //选取清单项并传回密度值
                   (setq f_id (open "d:\\LX\\jg2.txt" "r"))
                 (if (> tmp_r 0)
                                 (repeat tmp_r (read-line f_id)))
 (setq tmp_s (read-line f_id))
 (close f_id)
 (set_tile "jg_md" tmp_s)                                  //把得到的密度值传给密度编辑框
zl:dialog{
       label="液压工具箱五金手册——重量计算";
        :row{
          :popup_list{  label="等边角钢";
                        key="jg_l";
                        width=25;
                        heigth=8;
                        fixed_width=true;
                        fixed_heigth=true;
             :edit_box{
                       label="单位密度(kg/m)";
                        key="jg_md";
                        width=25;
                        heigth=8;
                        fixed_width=true;
                        fixed_heigth=true;
                        value="0";
             :edit_box{
                       label="长度(m)";
                        key="jg_cd";
                        width=25;
                        heigth=8;
                        fixed_width=true;
                        fixed_heigth=true;
                        value="0";
             :edit_box{
                       label="重量(kg)";
                        key="jg_zl";
                        width=25;
                        heigth=8;
                        fixed_width=true;
                        fixed_heigth=true;
                        value="0";
          ok_only;
 楼主| 发表于 2008-10-28 17:45:00 | 显示全部楼层
顶一下,希望高手能帮帮忙!!!
发表于 2008-10-29 08:15:00 | 显示全部楼层
 楼主| 发表于 2008-10-29 19:02:00 | 显示全部楼层
发表于 2008-10-30 07:51:00 | 显示全部楼层
无数据不知错在哪?
GMT+8, 2025-9-21 14:05 , Processed in 0.179504 second(s), 25 queries , Gzip On.
