查看: 1190|回复: 2
jxlsp帮忙看看怎么弄DLL文件
发表于 2008-10-29 12:36:00 | 显示全部楼层 |阅读模式
你的dll是这样的
showbmp;
Dispatch _vbmpApp;
GUID={D70D494A-388F-4AE3-9040-D50806AD1403};
  function QueryInterface(riid:^GUID; out ppvObj:^^void);
  function AddRef: UI4;
  function Release: UI4;
  function GetTypeInfoCount(out pctinfo:^UINT);
  function GetTypeInfo(itinfo:UINT; lcid:UI4; out pptinfo:^^void);
  function GetIDsOfNames(riid:^GUID; rgszNames:^^I1; cNames:UINT; lcid:UI4; out rgdispid:^I4);
  function Invoke(dispidMember:I4; riid:^GUID; lcid:UI4; wFlags:UI2; pdispparams:^DISPPARAMS; out pvarResult:^variant; out pexcepinfo:^EXCEPINFO; out puArgErr:^UINT);
  function vbmp(AcadApp:IDispatch);
Class vbmpApp;
GUID={BFF0745A-8B46-46C5-BBDA-227F7887F853};
我的是
showbmp;
Dispatch _vbmpapp;
GUID={7AFB3CAE-6A7D-4280-9512-828FF5C8CC04};
Class vbmpapp;
GUID={C19DC298-CE68-431E-9302-7494F065ACB7};
区别:少了function vbmp(AcadApp:IDispatch);
请问如何修改!!!怎么把他添加进DLL文件里!!!
发表于 2008-10-29 19:35:00 | 显示全部楼层
你上面的我不懂,我是用ResHacker.exe改的图.但有的又改不了,你问版主吧,因为加载问题没解决,所以没研究了.
 楼主| 发表于 2008-10-29 19:36:00 | 显示全部楼层
谢谢回复!
GMT+8, 2025-9-21 13:59 , Processed in 0.179242 second(s), 25 queries , Gzip On.
