查看: 1168|回复: 4
已经两天了,求助!!
发表于 2008-11-4 15:28:00 | 显示全部楼层 |阅读模式
(DEFUN C:CX () ;/ a b cxm sx sx1   ;查询扩展数据
  (SETQ A (ENTGET (CAR (ENTSEL)) '("*")))
  (SetQ B (Cdr (Assoc -3 A)))
  (SETQ CXM (CAR (CAr B)))
  (SETQ SX1 (CDr (CAr B)))
  (SETQ SX (CDR (CAr SX1)))
  (Alert (strcat "\n属性:" "  " SX))
(Defun c:xx ()  ;修改扩展数据
  (While (Not (SetQ a (EntSel "\n选择一个实体: ")))
    (Alert "没选中任何实体...")
  (SETQ plist (ENTGET (car a)))
  (SetQ v (GetString "\n属性: ")
 L (Cons 1000 v)
  (REGAPP "SX")
  (SETQ AAA (LIST (LIST -3 (LIST "SX" L))))
  (setq newB (append Plist AAA))
  (entmod newB)
  (PRINC)
(PRINC)
下面这一段就不行了
(defun c:AA()
  (setq pt (getpoint "\n框选第一点"))
  (setq spl (ssget "c" pt (getcorner pt) '((8 . "gcd") (2 . "gc200"))))
  (setq e (ssname spl 0))
  ;(setq e1 (entget (car e)))
  ;(setq eenn (entget (CAR SPL )))
  ;(SETQ CXM (CAR (CAr BBB)))
  ;(SETQ SX1 (CDr (CAr BBB)))
  ;(SETQ SX (CDR (CAr SX1)))
发表于 2008-11-4 15:32:00 | 显示全部楼层
全是些基本操作,多看书
 楼主| 发表于 2008-11-4 15:37:00 | 显示全部楼层
为什么
1  SETQ A (ENTGET (CAR (ENTSEL)) '("*")))
2 (While (Not (SetQ a (EntSel "\n选择一个实体: ")))
两种都可以
3  (setq pt (getpoint "\n框选第一点"))
就不行那了
发表于 2008-11-4 16:05:00 | 显示全部楼层
(setq spl (ssget "c" pt (getcorner pt) '((cons 8  "gcd") (cons 2  "gc200"))))
这样试一下
 楼主| 发表于 2008-11-4 16:32:00 | 显示全部楼层
后面加了一句
(SETQ XDATA (CDADR (ASSOC -3 (ENTGET e'("*")))))
    (SETQ SX (CDr (CAr XDATA)))
解决
GMT+8, 2025-9-21 14:32 , Processed in 0.588040 second(s), 25 queries , Gzip On.
