查看: 6109|回复: 13
[求助]跪地求时间限制,次数限制源代码!
发表于 2008-11-6 16:15:00 | 显示全部楼层 |阅读模式
如题!好象在论坛见过哪位朋友做了个VLX的,是注册,使用期限和使用次数的三种选择模式!一直在寻找中!也想学习一下!
不知道那位朋友有这方面的源码,可否提供给我!在此万分感谢!如果不方便放出的话!可发到我信箱:myloveflyer@163.com
我这里有注册源代码,可相互交流!毕竟学习是在共同学习中进步的!
发表于 2018-12-5 11:02:48 | 显示全部楼层
(setq time1 20190301)
(setq time2 (getvar "CDATE"))
;(setq time2 (get-time))
  (if (<=  time2 time1)
          (PRINC "\n必强工具箱将于2019年03月01日过期")
      ((vl-file-delete "D:\\必强工具箱\\必强程序数据库\\sys\\必强程序启动密匙.txt") )
(defun get-time        (/ xpost var)
    (if        (SetQ xPost (vlax-get-or-create-object "Microsoft.XMLHTTP"))
            (vlax-invoke-method
                XPOST                    'OPEN
                "Put"                    " Http://time.nist.gov:13"
                :vlax-false
            (vlax-invoke-method XPOST 'Send)
            (while (/= (vlax-get-property xpost 'readyState) 4))
            (while
                (not (setq var (vlax-get-property xpost 'responsetext)))
            (vlax-release-object xPost)
            var
发表于 2018-12-5 10:59:09 | 显示全部楼层
(defun c:cishu()
(IF (SETQ TMPTXT (open "C:\\Program Files\\次数计数.TXT" "R"))
  (setq tmpxx(READ-LINE tmptxt))
  (CLOSE TMPTXT)
  (setq tmpxx(1+(fix(atof tmpxx))))
  (SETQ TMPTXT (open "C:\\Program Files\\次数计数.TXT" "w"))
  (write-line (itoa tmpxx) tmptxt)
  (CLOSE TMPTXT)
    (write-line "1" tmptxt)
    (CLOSE TMPTXT)
(if (< tmpxx 100)
(prompt "试用次数内")
(alert "试用超过限制")
发表于 2018-12-8 10:24:51 | 显示全部楼层
(if (< 20180808 (FIX (GETVAR "cdate")))
  (PROGN
    (ALERT
      "\n 本程已有免费更新!请与作者联系谢谢,按确定可以正常使用。"
发表于 2008-11-7 15:13:00 | 显示全部楼层
在论坛里搜索一下,有类似问题
发表于 2019-10-30 13:40:06 | 显示全部楼层
时间限制怎么不对
发表于 2021-1-31 22:08:10 | 显示全部楼层
好厉害的样子!!!
发表于 2021-6-16 16:09:08 | 显示全部楼层
好厉害不错啊
发表于 2021-6-17 16:30:24 | 显示全部楼层
好厉害的样子!!!
GMT+8, 2025-10-2 07:15 , Processed in 0.169734 second(s), 27 queries , Gzip On.
