查看: 1498|回复: 2
[lisp调用dcl的问题
发表于 2008-11-6 18:44:00 | 显示全部楼层 |阅读模式
lisp:
(defun c:dia5b()
   (setvar "cmdecho" 0)
   (dcl_dia5b)
   (prin1)
(defun dcl_dia5b()
   (setq dcl_id (load_dialog "dia5b"))
   (new_dialog "dia5b" dcl_id)
   (set_tile "kww" "50")
   (set_tile "khh" "50")
   (action_tile "bb1" "(get_ww_hh)(done_dialog 1)")
   (action_tile "bb2" "(get_ww_hh)(done_dialog 2)")
   (action_tile "bb3" "(get_ww_hh)(done_dialog 3)")
   (setq dd (start_dialog))
   (cond ((= dd 1)(c:dia5b1))
   ((= dd 2)(c:dia5b2))
         ((= dd 3)(c:dia5b3))
         (t (alert "未完成任何动作!!!!"))
(defun get_ww_hh()
   (setq ww(atof (get_tile "kww")))
   (setq hh(atof (get_tile "khh")))
(defun c:dia5b1()
   (get_input_data)
   (command "pline" p1 p2 p3 pm34 pm pm14 "c")
   (prin1)
(defun c:dia5b2()
   (get_input_data)
   (command "pline" p1 p2 p3 p4 "c")
   (command "line" p1 p3 "")
   (command "line" p2 p4 "")
   (prin1)
(defun c:dia5b3()
   (get_input_data)
   (command "pline" p1 p2 p4 p3 "c")
   (prin1)
(defun get_input_data()
   ;;;(setq ww (getreal "宽度WW:"))
   ;;;(setq hh (getreal "\n高度HH:"))
   (setq p1 (getpoint "\n插入点:"))
   (setq p2 (polar p1 0 ww))
   (setq p3 (polar p2 (* pi 0.5) hh))
   (setq p4 (polar p3 pi ww))
   (setq pm  (inters p1 p3 p2 p4))
   (setq pm12(polar p1 0  (* ww 0.5)))
   (setq pm34(polar p3 pi (* ww 0.5)))
   (setq pm23(polar p2 (* pi 0.5) (* hh 0.5)))
   (setq pm14(polar p1 (* pi 0.5) (* hh 0.5)))
dcl:
dia5b:dialog{
 label="按钮测试范例";
  :boxed_row{
  label="图形尺寸";
  :edit_box{label="宽度WW";key="kww";edit_width=8;}
  :edit_box{label="高度HH";key="khh";edit_width=8;}
 :button{label="绘制 DIA5B1 →  L   型";key="bb1";}
 :button{label="绘制 DIA5B2 →  X   型";key="bb2";}
 :button{label="绘制 DIA5B3 → 漏斗型";key="bb3";}
 spacer_1;
 cancel_button;
我把这两个文件放在同一个文件夹内,运行LISP程序不调用DCL,只有在 (setq dcl_id (load_dialog "dia5b"))
中指定路径才能正常运行,如何不指定路径也能正常运行?
发表于 2008-11-6 20:30:00 | 显示全部楼层
方法1:将DCL文件放在AutoCAD搜索路径里,即Options命令->Files->Support file search path,在此添加搜索路径;
方法2:将DCL文件与LSP文件一起编译到一个VLX文件中,这时LSP中不需要指定路径.
 楼主| 发表于 2008-11-7 11:33:00 | 显示全部楼层
谢谢了,我试试
GMT+8, 2025-9-21 14:32 , Processed in 0.190933 second(s), 26 queries , Gzip On.
