查看: 1182|回复: 1
选择集应用一列
发表于 2008-11-9 15:45:00 | 显示全部楼层 |阅读模式
通过选择交叉实体,返回选择集内包括文本实体。
Function CreateSelectionSetCrossingText(pt1 As Variant, pt2 As Variant) As AcadSelectionSet
   On Error Resume Next
   Dim sSet As AcadSelectionSet
   'Dim SSet As AcadSelectionSet
   If Not IsNull(ThisDrawing.SelectionSets.Item("SelectEntity")) Then
     Set sSet = ThisDrawing.SelectionSets.Item("SelectEntity")
     sSet.Delete
   End If
   Set sSet = ThisDrawing.SelectionSets.Add("SelectEntity")
   Dim gpCode(0) As Integer
   Dim dataValue(0) As Variant
   gpCode(0) = 0
   dataValue(0) = "Text"
   sSet.Select acSelectionSetCrossing, pt1, pt2, gpCode, dataValue
   Set CreateSelectionSetCrossingText = sSet
End Function
Sub lsls()
  Dim pt1, pt2
  pt1 = ThisDrawing.Utility.GetPoint(, "Input First Point")
  pt2 = ThisDrawing.Utility.GetCorner(pt1, "Input First Point")
  Set sSet = CreateSelectionSetCrossingText(pt1, pt2)
  Dim objText As AcadText
  For ii = 0 To sSet.Count - 1
    Set objText = sSet.Item(ii)
    Debug.Print objText.TextString
  Next ii
End Sub
发表于 2008-11-11 08:02:00 | 显示全部楼层
兰州人发贴,属于精品,顶。
GMT+8, 2025-2-22 02:51 , Processed in 0.182688 second(s), 23 queries , Gzip On.
