查看: 3199|回复: 8
路径保存在何处?
发表于 2002-5-15 10:29:00 | 显示全部楼层 |阅读模式
那位大虾能告诉一下,AutoCAD的support file(例如字体路径等)保存在什么文件中?
发表于 2002-5-15 11:00:00 | 显示全部楼层
*.ARG。找它做什么用?
[此贴子已经被陈伯雄于2002-5-15 11:00:38编辑过]
 楼主| 发表于 2002-5-15 11:08:00 | 显示全部楼层
哪有此类文件?我想做个自己的安装程序!
哪有此类文件?我想做个自己的安装程序!
发表于 2002-5-15 11:09:00 | 显示全部楼层
您用的不是AutoCAD么?什么版本?下面是AutoCAD2002的AutoCAD.ARG全文...
REGEDIT4
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD]
"UserName"="CBX CBX, ."
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Acadm]
"Version"="ACADM-6:804"
"Release"="15.0"
"NotYetStarted"=dword:00000001
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Command Line Windows]
"CmdLine.ForeColor"=dword:00000000
"CmdLine.BackColor"=dword:00FFFFFF
"TextWindow.ForeColor"=dword:00000000
"TextWindow.BackColor"=dword:00FFFFFF
"CmdLine.FontFace"="幼圆"
"CmdLine.FontHeight"=dword:0000000B
"CmdLine.FontWeight"=dword:00000190
"CmdLine.FontItalic"=dword:00000000
"CmdLine.FontPitchAndFamily"=dword:00000031
"TextWindow.FontFace"="幼圆"
"TextWindow.FontHeight"=dword:0000000B
"TextWindow.FontWeight"=dword:00000190
"TextWindow.FontItalic"=dword:00000000
"TextWindow.FontPitchAndFamily"=dword:00000031
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\acad-200]
"X"=dword:000000E7
"Y"=dword:00000112
"Width"=dword:0000034B
"Height"=dword:000001E5
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\acad-506]
"X"=dword:00000166
"Y"=dword:00000189
"Width"=dword:00000234
"Height"=dword:000000EE
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\AcDim:DimstyleFormat]
"ActiveTab"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\AllAnavDialogs]
"lacesOrder"="History|Desktop|Personal|Favorites|Redspark|FTP"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\ColorOptionsDialog]
"X"=dword:000001B3
"Y"=dword:00000141
"Width"=dword:0000019A
"Height"=dword:0000017E
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\OptionsDialog]
"ActiveTab"=dword:00000008
"X"=dword:000000D4
"Y"=dword:000000E1
"Width"=dword:00000358
"Height"=dword:0000023E
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\ProfileExportFileDialog]
"FileNameMRU0"="AutoCAD"
"InitialFilterIndex"=dword:00000000
"ViewMode"=dword:00000003
"InitialDirectory"="C:\\User\\2000User\\Support\\"
"reviewVisible"=dword:00000000
"X"=dword:000000EF
"Y"=dword:00000106
"Width"=dword:00000322
"Height"=dword:000001F5
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\RightClickCustomizeDialog]
"ShortcutMenu"=dword:0000000B
"X"=dword:00000188
"Y"=dword:0000013C
"Width"=dword:000001F0
"Height"=dword:00000188
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\Startup Dialog]
"X"=dword:00000158
"Y"=dword:00000146
"Width"=dword:00000250
"Height"=dword:00000175
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Dialogs\选择菜单文件]
"X"=dword:000000EF
"Y"=dword:00000106
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Drawing Window]
"Background"=dword:00000000
"Layout background"=dword:00FFFFFF
"XhairPickboxEtc"=dword:00C0C0C0
"LayoutXhairPickboxEtc"=dword:00000000
"Autotracking vector"=dword:00808080
"lot preview background"=dword:00FFFFFF
"MonoVectors"=dword:00000000
"FontFace"="MS Sans Serif"
"FontHeight"=dword:00000008
"FontWeight"=dword:00000190
"FontItalic"=dword:00000000
"FontPitchAndFamily"=dword:00000000
"CursorSize"=dword:00000064
"ForeColor"=dword:00000000
"BackColor"=dword:00FFFFFF
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Editor Configuration]
"LogFilePath"="C:\\user\\2000user\\"
"EmergencyFont"="simplex.shx"
"FontMappingFile"="C:\\Program Files\\Common Files\\Autodesk Shared\\acad.fmp"
"ACADLspAsDoc"=dword:00000000
"SOUT_PrologFileName"=""
"MainDictionary"="enu"
"CustomDictionary"="C:\\Program Files\\Common Files\\Autodesk Shared\\sample.cus"
"MTextEditor"="内部"
"XrefLoadPath"="E:\\temp\\Autodesk"
"SaveFilePath"="C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp\\"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\General]
"ACAD"="C:\\User\\2000User\\Support;C:\\Program Files\\Common Files\\Autodesk Shared;C:\\Program Files\\MDT5sc\\;C:\\Program Files\\MDT5sc\\Support;C:\\Program Files\\MDT5sc\\Fonts;C:\\Program Files\\MDT5sc\\Express;C:\\Program Files\\MDT5sc\\help;C:\\User\\2000User;"
"TemplatePath"="C:\\Program Files\\MDT5sc\\template"
"ACADDRV"="C:\\Program Files\\MDT5sc\\drv"
"ACADHELP"="C:\\Program Files\\MDT5sc\\help\\acad.chm"
"rinterConfigDir"="C:\\Program Files\\MDT5sc\\plotters"
"rinterStyleSheetDir"="C:\\Program Files\\MDT5sc\\Plot Styles"
"rinterDescDir"="C:\\Program Files\\MDT5sc\\drv"
"NewStyleSheet"=""
"DefaultFormatForSave"=dword:0000000C
"ACADLOGFILE"="C:\\user\\2000user\\acad.log"
"AVEMAPS"="C:\\Program Files\\MDT5sc\\textures"
"DatabaseWorkSpacePath"="C:\\Program Files\\MDT5sc\\Data Links"
"DefaultPlotStyle"="ByLayer"
"DefaultLayerZeroPlotStyle"="Normal"
"LineWeightUnits"=dword:00000001
"DefaultConfig"="传真"
"LWDEFAULT"=dword:00000019
"LastModifiedConfig"="传真"
"Scrollbars"=dword:00000000
"CustomColors"=dword:00000001
"MRUConfig"="传真"
"DoubleClickEdit"=dword:00000001
"MaxDwg"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\General Configuration]
"MenuFile"="C:\\Program Files\\MDT5sc\\support\\acad"
"TempDirectory"="E:\\temp\\Autodesk\\"
"lotSpoolerDirectory"="C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp\\"
"DefaultLoginName"=""
"IsavePercent"=dword:00000032
"NetLocation"="C:\\Program Files\\MDT5sc\\home.htm"
"Today_WorkMode"=dword:00000002
"Use TODAY as Startup dialog"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Mcad]
"Version"="MCAD-6:804"
"Release"="5"
"roduct"="VAC"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Menus]
"op1"="ACAD pop1"
"op2"="ACAD pop2"
"op3"="ACAD pop3"
"op4"="ACAD pop4"
"op5"="ACAD pop5"
"op6"="ACAD pop6"
"op7"="ACAD pop7"
"op8"="ACAD pop8"
"op9"="ACAD pop9"
"op10"="ACAD pop10"
"op11"="ACAD pop11"
"op500"="ACAD pop500"
"op501"="ACAD pop501"
"op502"="ACAD pop502"
"op503"="ACAD pop503"
"Group1"="USER2000i C:\\User\\2000User\\Support\\USER2000"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Previous plot settings]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Previous plot settings\Layout]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Previous plot settings\Model]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Project Settings]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD\Toolbars]
"ACAD.TB_DIMENSION"="hide float 100 130 1"
"ACAD.TB_DRAW"="hide float 289 105 1"
"ACAD.TB_INQUIRY"="hide float 100 170 1"
"ACAD.TB_INSERT"="hide float 100 190 1"
"ACAD.TB_LAYOUTS"="hide float 100 350 1"
"ACAD.TB_MODIFY"="hide float 243 296 1"
"ACAD.TB_MODIFY_II"="hide float 100 270 1"
"ACAD.TB_OBJECT_PROPERTIES"="show top 0 1"
"ACAD.TB_OBJECT_SNAP"="hide float 100 210 1"
"ACAD.TB_ORBIT"="hide float 100 350 1"
"ACAD.TB_SHADING"="hide float 100 390 1"
"ACAD.TB_REFEDIT"="hide float 100 170 1"
"ACAD.TB_REFERENCE"="hide float 100 370 1"
"ACAD.TB_RENDER"="hide float 100 230 1"
"ACAD.TB_SOLIDS"="hide float 100 250 1"
"ACAD.TB_SOLIDS2"="hide float 100 250 1"
"ACAD.TB_STANDARD"="show top 0 0"
"ACAD.TB_SURFACES"="hide float 100 290 1"
"ACAD.TB_UCS"="hide float 100 310 1"
"ACAD.TB_UCSII"="hide float 100 300 1"
"ACAD.TB_VIEWPOINT"="hide float 100 330 1"
"ACAD.TB_VIEWPORTS"="hide float 100 350 1"
"ACAD.TB_WEB"="hide float 100 380 1"
"ACAD.TB_ZOOM"="hide float 100 350 1"
"LargeButtons"="no"
"ToolTips"="yes"
"ShowShortcuts"="yes"
"USER2000i.USER2000i"="show top 1 1"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\FixedProfile]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\FixedProfile\Application Window]
"Show"=dword:00000003
"osition"="2 2 1278 990"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\FixedProfile\Command Line Windows]
"CmdLine.Rows"=dword:00000003
"DockWindow.Style"=dword:00000002
"DockWindow.Position"="-1 919 1281 997"
"TextWindow.Show"=dword:00000001
"TextWindow.Position"="240 239 1201 710"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\FixedProfile\Drawing Window]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\FixedProfile\Editor Configuration]
"SDF_AttributeExtractTemplateFile"=""
"AutoSnapColor"=dword:00000001
"AutoSnapControl"=dword:00000007
"AutoSnapPolarAng"="0.19198621771937624"
"AutoSnapPolarDistance"="50"
"UcsIconSize"=dword:00000008
"AutoSnapPolarAddAng"="0.40142572795869574;0.78539816339744828;1.1693705988362009"
"UcsIconActiveColor"=dword:00000002
"ObjectSnapCursorSize"=dword:00000007
"AutoSnapSize"=dword:00000003
"SnapType"=dword:00000001
"UcsIconLineWidth"=dword:00000002
"GripColor"=dword:00000004
"UCSOrtho"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\FixedProfile\General]
"ActiveAssistance"=dword:00000000
"ANSIHatch"="acad.pat"
"ANSILinetype"="acad.lin"
"ISOHatch"="acadiso.pat"
"ISOLinetype"="acadiso.lin"
"Measureinit"=dword:00000001
"InsertUnitsDefSource"=dword:00000004
"InsertUnitsDefTarget"=dword:00000004
"StartUpType"="Template"
"LastTemplate"="C:\\Program Files\\MDT5sc\\template\\2000.dwt"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\FixedProfile\General Configuration]
"QAFlags"=dword:00000010
发表于 2002-5-15 11:20:00 | 显示全部楼层
关于安装程序...
1〉AutoCAD有自己的规则,您的安装程序应当顺应这个规则
2〉这就是AutoCAD安装路径下的\Support,所有的支持文件都应放在此处
3〉而AutoCAD的安装路径在系统注册表中很容易找到
4〉Support路经集中很可能包括有用户自己的定义,所以搜索到了也没有意义
5〉您既然在给AutoCAD写程序,上述规则恐怕您一定了解。我是重复一下而已...
 楼主| 发表于 2002-5-15 11:54:00 | 显示全部楼层
autocad安装在不同的机器上注册表中HKEY_CURRENT_USER中的键不同!
autocad安装在不同的机器上注册表中HKEY_CURRENT_USER中的键不同!HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-6:804\Profiles\AutoCAD
ACAD-6:804不一定是这样!(ACAD-6:804)的意义仅仅是版本? 谢谢!
 楼主| 发表于 2002-5-15 12:02:00 | 显示全部楼层
autocad2000!
autocad20001
发表于 2002-5-15 13:41:00 | 显示全部楼层
去弄个wise installer
AutoCAD2002中文版本身的安装程序,也是用wiseInstaller做的
我用wise installer做了AutoCAD2000下的安装程序,很好。当然要在中间嵌入一段初始化AutoCAD的程序,这段程序用VB写。
发表于 2002-5-15 13:43:00 | 显示全部楼层
所以不要指定一个固定的注册表项,要在程序里进行注册表查找和份析
GMT+8, 2025-5-21 07:10 , Processed in 0.172332 second(s), 24 queries , Gzip On.
