- 积分
- 5989
- 明经币
- 个
- 注册时间
- 2006-7-8
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
在Excel中输入以下程序
Sub ls()
Dim AppCAD As AcadApplication
On Error Resume Next
Set AppCAD = GetObject(, "AutoCAD.Application")
If Err Then
Debug.Print Err.Number
Err.Clear
Set AppCAD = CreateObject("AutoCAD.Application")
End If
AppCAD.Visible = True
Dim objModelSpace As AcadModelSpace
Dim objDocument As AcadDocument
Set objModelSpace = AppCAD.ActiveDocument.ModelSpace
Set objDocument = AppCAD.ActiveDocument
End Sub - Sub lll()
- Dim objRegion As Variant
- Dim objCurve() As AcadEntity
- With ConnectCad.ActiveDocument
- ReDim objCurve(Range("A65366").End(xlUp).Row - 2) As AcadEntity
- Debug.Print Range("A65366").End(xlUp).Row, .ModelSpace.Count - 1
- For ii = 2 To Range("A65366").End(xlUp).Row
- Set objCurve(ii - 2) = .HandleToObject(Cells(ii, 1))
- Next ii
- Dim regionObj As Variant
- regionObj = .ModelSpace.AddRegion(objCurve)
- ' Define the extrusion
- Dim Height As Double
- Dim taperAngle As Double
- Height = 20
- taperAngle = 0
- ' Create the solid
- Dim SolidObj As Acad3DSolid
- Set SolidObj = .ModelSpace.AddExtrudedSolid(regionObj(0), Height, taperAngle)
- SolidObj.Color = 1
- ' Change the viewing direction of the viewport
- Dim NewDirection(0 To 2) As Double
- NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
- .ActiveViewport.Direction = NewDirection
- .ActiveViewport = .ActiveViewport
- ZoomExtents
- End With
- End Sub
 - Function ConnectCad() As AcadApplication
- Dim App As AcadApplication
- On Error Resume Next
- Set App = GetObject(, "AutoCAD.Application")
- If Err Then
- Err.Clear
- Set App = CreateObject("AutoCAD.Application")
- End If
- App.Visible = True
- Set ConnectCad = App
- End Function
- Function GetCornerSelect(sSetName As String, fTypeVariant As Variant, fDataVariant As Variant) As AcadSelectionSet
- Dim sSet As AcadSelectionSet
- Dim fType() As Integer, fData() As Variant
- ReDim fType(UBound(fTypeVariant) + 2) As Integer: ReDim fData(UBound(fDataVariant) + 2) As Variant
- fType(0) = -4: fData(0) = "<Or"
- For ii = 0 To UBound(fTypeVariant)
- fType(ii + 1) = fTypeVariant(ii): fData(ii + 1) = fDataVariant(ii)
- Next ii
- fType(UBound(fType)) = -4: fData(UBound(fData)) = "Or>"
- Dim Pt1, Pt2
- Set sSet = .SelectionSets.Item(sSetName)
- sSet.Delete
- Set sSet = .SelectionSets.Add(sSetName)
- Pt1 = .Utility.GetPoint(, "Select Forst Point")
- Pt2 = .Utility.GetCorner(Pt1, "Select Corner Point")
- sSet.Select acSelectionSetCrossing, Pt1, Pt2, fType, fData
- End With
- Set GetCornerSelect = sSet
- End Function
- Sub l()
- nn = 0
- ReDim fType(nn) As Integer: ReDim fData(nn) As Variant
- fType(0) = 8: fData(0) = "0"
- Set sSet = GetCornerSelect("testSset", fType, fData)
- End Sub
