查看: 3504|回复: 12
[讨论]关于所有圆一次加上中心线的问题
发表于 2008-11-23 10:30:00 | 显示全部楼层 |阅读模式
请高手帮忙看下面的程序代码,为什么总是提示不成功呢?
(defun CMDLA0 ()
  (setq cmdech (GETVAR "CMDECHO"))
  (setq oom (getvar "orthomode"))
  (setq osm (getvar "osmode"))
  (SETQ LA (getvar "clayer"))
  (setvar "regenmode" 1)
  (SETVAR "CMDECHO" 0)
(defun CMDLA1 ()
  (SETVAR "CMDECHO" cmdech)
  (setvar "orthomode" oom)
  (setvar "osmode" osm)
  (setvar "clayer" LA)
;;; 每个圆心插入垂直交叉直线
  (defun c:cl ()
    (CMDLA0)
    (setq ss (ssget '((0 . "CIRCLE")))
   i  -1
    (mkla "中心线" 1)
    (while (setq s1 (ssname ss (setq i (1+ i)))))
      (setq p0 (cdr (assoc 10 (entget s1)))
     l  (cdr (assoc 40 (entget s1)))
      (xyp_szx p0 (* l 0.25))  ; 0.25倍直径
    (CMDLA1)
(Defun MKLA (a b)
  (If (= (Tblsearch "layer" a) nil)
    (Command "layer" "m" a "c" b a "")
    (Command "layer" "t" a "s" a "c" b a "")
发表于 2008-11-23 11:13:00 | 显示全部楼层
这个是我以前做的
(defun c:df()
(setq os (getvar "osmode"))
(setvar "osmode" 0)
(setq ss (ssget '((0 . "CIRCLE"))))
(setq len (sslength ss))
(setq n 0)
(command "undo" "begin")
(repeat len
(setq ent (ssname ss n))
(setq dxf (entget ent))
(setq yuanxin (trans (cdr (assoc 10 dxf)) 0 1))
(setq banjing (cdr (assoc 40 dxf)))
(setq waiyan (* banjing 1.5))
(setq p1 (polar yuanxin pi waiyan))
(setq p2 (polar yuanxin 0 waiyan))
(setq p3 (polar yuanxin (/ pi 2) waiyan))
(setq p4 (polar yuanxin (* 1.5 pi) waiyan))
(command "line" p1 p2 "")
(setq last1 (entlast))
(command "line" p3 p4 "")
(setq last2 (entlast))
(setq n (+ 1 n))
(command "undo" "end")
(setvar "osmode" os)
此段程序太好了.如果已经有中心线的圆,不再加中心线就更棒了.  发表于 2011-2-27 11:40
 楼主| 发表于 2011-2-27 11:06:11 | 显示全部楼层
发表于 2011-3-7 20:03:40 | 显示全部楼层
发表于 2011-3-20 11:32:20 | 显示全部楼层
看看
谢谢~
 楼主| 发表于 2011-5-31 12:55:28 | 显示全部楼层
好帖
发表于 2011-5-31 16:41:17 | 显示全部楼层
感谢phoenixdjq楼主分享源码程序 < 谢谢! >
发表于 2011-5-31 17:05:50 | 显示全部楼层
回复 phoenixdjq 的帖子
如果你的中心線都是同一規格的,只要在程序中加入先行刪除就可以了
发表于 2011-5-31 20:07:36 | 显示全部楼层
zhd81617 发表于 2008-11-23 10:30
请高手帮忙看下面的程序代码,为什么总是提示不成功呢?(defun CMDLA0 ()&nbsp; (setq cmdech (GETVAR "CMD ...
初一看,缺少自定义函数xyp_szx
发表于 2011-5-31 21:55:42 | 显示全部楼层
圆中心线好写,关键在于如何判断同心圆,同心圆与圆弧,同心圆弧,如果这个处理好了就是一个非常好用的程式。
GMT+8, 2025-7-2 01:36 , Processed in 0.188955 second(s), 29 queries , Gzip On.
