查看: 1057|回复: 0
LinetypeScale应用一例
发表于 2008-11-27 16:42:00 | 显示全部楼层 |阅读模式
在一张图上的中心线,有的长,有的短,如果LinetypeScale都用1的话,有的中心线间距拉的开,有的就成为一条直线。
Sub lsls()
  Dim pt1, pt2
  Dim sSet As AcadSelectionSet
  pt1 = ThisDrawing.Utility.GetPoint(, "Input First Point")
  pt2 = ThisDrawing.Utility.GetCorner(pt1, "Input First Point")
  Set sSet = CreateSelectionSetCrossingText(pt1, pt2)
  Dim objText As AcadText
  Dim objLine As AcadLine
  For ii = 0 To sSet.Count - 1
    Set objLine = sSet.Item(ii)
    With objLine
      Debug.Print .Length
通过判断长度,来设置LinetypeScale的值。
      Select Case .Length
        Case Is <= 5
          .LinetypeScale = 0.1
        Case Is <= 10
          .LinetypeScale = 0.2
        Case Is > 50
          .LinetypeScale = 0.8
      End Select
    End With
  Next ii
End Sub
Function CreateSelectionSetCrossingText(pt1 As Variant, pt2 As Variant) As AcadSelectionSet
   On Error Resume Next
   'Dim SSet As AcadSelectionSet
   If Not IsNull(ThisDrawing.SelectionSets.Item("SelectEntity")) Then
     Set sSet = ThisDrawing.SelectionSets.Item("SelectEntity")
     sSet.Delete
   End If
   Set sSet = ThisDrawing.SelectionSets.Add("SelectEntity")
   Dim gpCode(0) As Integer
   Dim dataValue(0) As Variant
   gpCode(0) = 0
   dataValue(0) = "Line"
   sSet.Select acSelectionSetCrossing, pt1, pt2, gpCode, dataValue
   Set CreateSelectionSetCrossingText = sSet
End Function
GMT+8, 2025-2-22 02:31 , Processed in 0.172071 second(s), 23 queries , Gzip On.
