查看: 1739|回复: 4
请教一个尺寸标注文字替代LISP,谢谢!
发表于 2008-12-2 13:47:00 | 显示全部楼层 |阅读模式
例15.000,1.输入命令后,2.输入字符"int” 3.选尺寸15.000(最好可复选)回车尺寸变成INT15.000
发表于 2008-12-3 21:07:00 | 显示全部楼层
(defun c:tt ()
 (if (setq stt (getstring "\n输入字符 :")) (progn
  (setq stt (strcat stt "<>"))
  (command ".DIMOVERRIDE" "DIMPOST" stt "")
发表于 2016-10-20 10:23:36 | 显示全部楼层
ZZXXQQ 发表于 2008-12-3 21:07
(defun c:tt ()&nbsp;(if (setq stt (getstring "\n输入字符 :")) (progn&nbsp; (setq stt (strcat stt " ...
你好,用了这段代码后在原标注尺寸前加了修改的尺寸,原来是1405,我修改成1400后变成14001405了
发表于 2016-10-20 10:46:12 | 显示全部楼层
那个代码是加前缀的,修改文字看看我这个古旧而简单的:
(defun c:nt()(command "dim1" "newtext"))
发表于 2016-10-20 11:00:32 | 显示全部楼层
简单粗暴而且有效
GMT+8, 2025-10-26 04:04 , Processed in 0.175491 second(s), 27 queries , Gzip On.
