查看: 2438|回复: 4
[求助] Presscad 图形加工说明问题
发表于 2008-12-7 16:46:00 | 显示全部楼层 |阅读模式
请问各位,Presscad 里面的图形不是块,但它们又可以像块一样 附带 属性,以便提取里面的加工说明。
这是怎样做到的?怎么样才可以提取及写入??
发表于 2008-12-7 20:59:00 | 显示全部楼层
是用了扩展数据
  (entget (car (entsel)) '("*")) 可以取出扩展数据
;;;给图元附上扩展数据
;;;用法(jx_set_xdata (car (entsel))  "test" (list(cons 1000 "test")))
(defun jx_set_xdata (en rname xd_list / old all elist)
  (setq elist (entget en '("*"))
 rname (strcase rname)
  (regapp rname)
  (setq xd_list (cons rname xd_list)
 old (assoc -3 elist)
  (cond
    ((and old (assoc rname (cdr old)))
     (setq all  (cons -3 (subst xd_list (assoc rname (cdr old)) (cdr old)))
    elist (subst all (assoc -3 elist) elist)
     (entmod elist)
    ((and old (not (member rname (cdr old))))
     (setq all  (append old (list xd_list))
     (entmod elist)
    ((not old)
     (setq xd_list (list -3 xd_list)
    elist   (append elist (list xd_list))
     (entmod elist)
 楼主| 发表于 2008-12-13 20:48:00 | 显示全部楼层
非常感谢。确实是这样
发表于 2024-2-29 19:47:35 | 显示全部楼层
非常感谢。了解了
GMT+8, 2025-2-22 17:28 , Processed in 0.179420 second(s), 25 queries , Gzip On.
