(vl-load-com) (defun c:test () (princ "\n选取*PLINE多义线...") (setq ss (ssget '((0 . "lwpolyline"))) i -1 ptlst '() ) (setq F (getfiled "写出文件" "" "txt" 1)) (setq F (open F "w")) (if ss (progn (while (setq ssn (ssname ss (setq i (1+ i)))) (setq retcoord (vlax-ename->vla-object ssn) ) (setq px (cdr (assoc 10 (entget ssn)))) (setq py (cdr (assoc 10 (reverse(entget ssn))))) (setq handle (cdr(assoc 5 (entget ssn)))) (setq pt (list px py handle)) (setq ptlst (cons pt ptlst)) ) (princ "\n多义线顶点坐标集(!ptlst) : ") (if ptlst (princ ptlst) ) ) (princ "\n未选到多义线!") ) (princ) ;;;判断坐标 ;;(while ptlst (setq outlst '()) (setq obj1 (car ptlst)) (setq obj1_f (car obj1)) (setq obj1_e (cadr obj1)) (setq pptlst (cdr ptlst)) (setq outlst (caddr obj1)) ;;初步判断 (if(equal obj1_f obj1_e 0.1) (write-line (vl-princ-to-string outlst) F) (princ "完整闭合区域!") ) (while pptlst nil (setq obj2 (car pptlst) pptlst (cdr pptlst) obj2_f (car obj2) obj2_e (cadr obj2) han (caddr obj2) j 0) ;;;比较 (if(equal obj1_e obj2_f 0.1) (setq obj1_e obj2_e outlst (cons han outlst) pptlst (vl-remove (nth j pptlst) pptlst)) (write-line (vl-princ-to-string outlst) F) ) (if(equal obj1_e obj2_e 0.1) (setq obj1_e obj2_f outlst (cons han outlst) pptlst (vl-remove (nth j pptlst) pptlst)) (write-line (vl-princ-to-string outlst) F) ) (if(equal obj1_f obj1_e 0.1) (princ "yid") ) (princ "\n") ) )
在执行时只能输出两个句柄,不能输出全部。 望各位帮忙啊,谢谢各位了,等急用! |
