在用VBA时,使用以给定的面域绕轴创建旋转实体的Addrevolvesolid语句时,旋转成三维。
AxisPoint
Variant[变体] (三元素双精度数组); 仅用于输入
指定旋转轴起点的三维WCS坐标。
AxisDir (理角不透,旋转成形后,三维旋转体成变形)
指定旋转轴方向的三维矢量。
解决这个问题只能lisp语句才能实现,原因何在
gg = "(command ""Revolve"" qq """" ""o"" qqq """" )"
ThisDrawing.SendCommand gg & vbCr
程序如下 - Sub Example_AddRevolvedSolid()
- ' 该示例通过面域沿一个轴旋转以创建实体。
- ' 面域是由一个弧和一根直线创建的。
- Dim curves(0 To 1) As AcadEntity
- ' 定义圆弧
- Dim centerPoint(0 To 2) As Double
- Dim radius As Double
- Dim startAngle As Double
- Dim endAngle As Double
- centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
- radius = 2#
- startAngle = 0
- endAngle = 3.141592
- ' 定义旋转轴
- Dim axisPt(0 To 2) As Double
- Dim axisDir(0 To 2) As Double
- Dim angle As Double
- Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
- ' 定义直线
- Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).StartPoint, curves(0).EndPoint)
- pp = curves(0).StartPoint
- For ii = 0 To 0
- axisPt(ii) = pp(ii)
- Next ii
- ppp = curves(0).EndPoint
- ' 创建面域
- Dim regionObj As Variant
- regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
- tt = "(setq qq (handent """ & regionObj(0).Handle & """))"
- ThisDrawing.SendCommand tt & vbCr
- axisPt(0) = centerPoint(0): axisPt(1) = 0: axisPt(2) = 0
- axisDir(0) = centerPoint(0) + 2: axisDir(1) = 0: axisDir(2) = 0
- Set objLine = ThisDrawing.ModelSpace.AddLine(axisPt, axisDir)
- ttt = "(setq qqq (handent """ & objLine.Handle & """))"
- ThisDrawing.SendCommand ttt & vbCr
- objLine.color = 3
- angle = 6.28
- ' 创建实体
- gg = "(command ""Revolve"" qq """" ""o"" qqq """" )"
- ThisDrawing.SendCommand gg & vbCr
- End Sub
- Sub lll()
- tt = "(setq qq (handent ""ba""))"
- End Sub
