查看: 1025|回复: 0
新手上路,如何返回得到这个代码生成的多段线对象?
发表于 2009-1-3 15:01:00 | 显示全部楼层 |阅读模式
Sub gcorner()
Dim FstPnt As Variant
Dim SndPnt As Variant
On Error Resume Next
FstPnt = ThisDrawing.Utility.GetPoint(, "选取矩形第一角点:")
SndPnt = ThisDrawing.Utility.GetCorner(FstPnt, "选取矩形对角点:")
Call drawbox(FstPnt, SndPnt) '调用画矩形子程序
End Sub
Private Function drawbox(p1, p2)    '根据对角线坐标画矩形的子程序
Dim boxp(0 To 14) As Double
boxp(0) = p1(0)
boxp(1) = p1(1)
boxp(3) = p1(0)
boxp(4) = p2(1)
boxp(6) = p2(0)
boxp(7) = p2(1)
boxp(9) = p2(0)
boxp(10) = p1(1)
boxp(12) = p1(0)
boxp(13) = p1(1)
Call ThisDrawing.ModelSpace.AddPolyline(boxp)
End Function
这是一段代码,调用drawbox函数绘制矩形,现在想调用这个多段线对象,不知道该如何获得?请教!
GMT+8, 2025-2-22 17:45 , Processed in 0.167627 second(s), 23 queries , Gzip On.
