(defun c:aream (/ olderr oldcmdecho errexit undox restore ss1 nr en tot_area) (defun errexit (s) (restore) )
(defun undox () (command "._undo" "_E") (setvar "cmdecho" oldcmdecho) (setq *error* olderr) (princ) ) (setq olderr *error* restore undox *error* errexit ) (setq oldcmdecho (getvar "cmdecho")) (setvar "cmdecho" 0) (command "._UNDO" "_BE") (if (setq ss1 (ssget '((-4 . "<OR") (0 . "POLYLINE") (0 . "LWPOLYLINE") (0 . "CIRCLE") (0 . "ELLIPSE") (0 . "SPLINE") (0 . "REGION") (-4 . "OR>") ) ) ) (progn (setq nr 0) (setq tot_area 0.0) (setq en (ssname ss1 nr)) (while en (command "._area" "_O" en) (setq tot_area (+ tot_area (getvar "area"))) (setq nr (1+ nr)) (setq en (ssname ss1 nr)) ) (princ "\nTotal Area = ") (princ tot_area) ) ) (restore) ) |
