查看: 1128|回复: 0
尺寸线复制给块,获得AcDbMtext
发表于 2009-2-7 10:25:00 | 显示全部楼层 |阅读模式
对于尺寸图元 dim objDim as AcadDimension
debug.print  objDim.TextOverride 有两种可能数据内容tt 或Empty.
以下程序可以解决,Debug.print 每个尺寸的数据.
Sub ls()
  Dim Ent As AcadEntity, objDim As AcadDimension
  Dim tempBlock As AcadBlock
  With ThisDrawing
    'Debug.Print .Blocks.Count, "ModelSpace:  " & .ModelSpace.Count
    For Each Ent In .ModelSpace
     If Ent.ObjectName Like "AcDb*Dimension" Then
       Set objDim = Ent.Copy()
       blkCount = .Blocks.Count
       Set tempBlock = .Blocks.Item(blkCount - 1)
       For jj = 0 To tempBlock.Count - 1
         Select Case tempBlock.Item(jj).ObjectName
           Case "AcDbMText"
             Debug.Print tempBlock(jj).TextString
             'Ent.TextOverride = tempBlock(jj).TextString
           Case "AcDbPoint"
         End Select
       Next jj
       objDim.Delete
     End If
     'Debug.Print .Blocks.Count, "ModelSpace" & .ModelSpace.Count
    Next Ent
  End With
End Sub
  1. [code]Sub ls()
  2.   Dim Ent As AcadEntity, objDim As AcadDimension
  3.   Dim tempBlock As AcadBlock
  4.   With ThisDrawing
  5.     'Debug.Print .Blocks.Count, "ModelSpace:  " & .ModelSpace.Count
  6.
  7.     For Each Ent In .ModelSpace
  8.
  9.      If Ent.ObjectName Like "AcDb*Dimension" Then
  10.        Set objDim = Ent.Copy()
  11.        blkCount = .Blocks.Count - 1
  12.        Debug.Print "BLKCOUNT", blkCount
  13. If blkCount + 1 And Left(.Blocks(blkCount).Name, 2) = "*D" Then
  14.         Set tempBlock = .Blocks.Item(blkCount)
  15.         Debug.Print objDim.Handle, tempBlock.Handle
  16.        For jj = 0 To tempBlock.Count - 1
  17.          Select Case tempBlock.Item(jj).ObjectName
  18.            Case "AcDbMText"
  19.              Debug.Print tempBlock(jj).TextString
  20.
  21.              'Ent.TextOverride = tempBlock(jj).TextString
  22.            Case "AcDbPoint"
  23.          End Select
  24.        Next jj
  25.        objDim.Delete
  26. End If
  27.      End If
  28.
  29.      'Debug.Print .Blocks.Count, "ModelSpace" & .ModelSpace.Count
  30.     Next Ent
  31.   End With
  32. End Sub
[/code]
GMT+8, 2025-6-3 09:19 , Processed in 0.148319 second(s), 23 queries , Gzip On.
