这个是秋枫的代码 ;;设置保存值 (defun SetValue (key value) (if (assoc key DCLValues) (setq DCLValues (subst (cons key value) (assoc key DCLValues) DCLValues ) ) (setq DCLValues (cons (cons key value) DCLValues)) ) ) ;;读取保存值 (defun GetValue (key / r) (if (assoc key DCLValues) (cdr (assoc key DCLValues)) (cdr (assoc key default_dclvalues)) ) ) |
