查看: 3710|回复: 6
为什么这段程序会报未找到主键?
发表于 2009-3-24 17:28:00 | 显示全部楼层 |阅读模式
我想找到一个BlockReference 然后更改它的NAME ,可到了最后一句总报未找到主键,魏森么呢?
Dim InsPoint(0 To 2) As Double
Dim NewEnt As AcadBlockReference
For Each Ent In ThisDrawing.ModelSpace
        If Ent.ObjectName = "AcDbBlockReference" Then
         Select Case Ent.Name 'EffectiveName
            Case "Motor_Cable"
            Set NewEnt = Ent.Copy
    Dim point1(0 To 2) As Double
    point1(0) = 2: point1(1) = 1: point1(2) = 0
            NewEnt.InsertionPoint = point1
        End Select
        End If
        Next
NewEnt.Name = "MotorAAA"  '这里报错
End Sub
谢谢!!
 楼主| 发表于 2009-3-25 09:36:00 | 显示全部楼层
顶一下 期待回答
发表于 2009-3-25 15:45:00 | 显示全部楼层
貌似思路不对,建新块,只能用blocks.add方法
 楼主| 发表于 2009-3-26 09:41:00 | 显示全部楼层
建新块也行,怎么能建一个新的把以前的那个所有信息都拷贝过来呢?  这些块只有编号不一样 图形什么的都一样啊
发表于 2009-3-26 14:00:00 | 显示全部楼层
你修改的应该是AcadBlock的name,AcadBlockReference的name是只读的
ThisDrawing.Blocks.Item(NewEnt.Name).Name = "MotorAAA"
发表于 2009-3-26 14:03:00 | 显示全部楼层
BlockRef: A block reference can be assigned the name of only a valid block definition in the drawing. Assigning a block reference a unique name will not automatically create a new block definition. To create a new block definition, use the MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_add.htm">Add method to add a new Block object to the Blocks collection.
 楼主| 发表于 2009-3-26 15:47:00 | 显示全部楼层
测试成功 太感谢了!!!!!!!!!!!!!!!
GMT+8, 2025-10-11 10:48 , Processed in 0.249257 second(s), 24 queries , Gzip On.
