查看: 2440|回复: 7
[求助]求高手帮忙写一段统计文字程序!
发表于 2009-3-27 10:14:00 | 显示全部楼层 |阅读模式
求高手将左边的文字统计成右边的表格,感激不尽!
 楼主| 发表于 2009-3-28 14:36:00 | 显示全部楼层
  1. (defun t_ins (p1 s h / ent)
  2.     (setq ent '((67 . 0)(0 . "TEXT"))
  3.    ent (cons (cons 40 h) ent)
  4.    ent (cons (cons 1 s) ent)
  5.    ent (cons (cons 10 p1) ent)
  6.    ent (reverse ent)
  7.     )
  8.     (entmake ent)
  9.   )
  10. (defun c:test1()
  11.     (command "-layer" "n" "pntext" "s""pntext""")
  12.   (setq Kuan (getreal "\n请输入冲针宽度增加量(0.1):")
  13. Chang (getreal "\n请输入冲针长度增加量(0.1):")
  14. Hao (getreal "\n请输入起始符号的整数(1):"))
  15.   (if (= Kuan nil) (setq Kuan "0.1"))
  16.   (if (= Chang nil) (setq Chang "0.1"))
  17.   (if (= Hao nil) (setq Hao "1"))
  18.   (setq p (getpoint "\n请确定报表输出位置:"))
  19.   (setq p (trans p 1 0))
  20. (setq sd (ssget "X" (list(cons 8 "PN1"))))
  21. (setq kx (ssget "X" (list(cons 8 "PN2"))))
  22. (setq a (sslength sd))
  23.    (setq a0 (cdr (assoc 10 (entget (ssname sd 0))))
  24.   a1 (cdr (assoc 1 (entget (ssname kx 0)))))
  25.   (setq k1 (substr a1 1 4)
  26. k2 (substr a1 6 4)
  27. kk1 (substr a1 10 4)
  28. kk2 (substr a1 15 2)
  29. kk3 (substr a1 17)
  30. k3 (rtos (+ (read k1) (read kuan)) 2 2)
  31. k4 (rtos (+ (read k1) (read chang)) 2 2))
  32.     (setq es (strcat Hao "  " k1 "  * " k2 kk1 kk2 " " k3 "  * " k4 "    " "" "  " "(" kk3 ")"))
  33.   (t_ins (mapcar '+ p '(-2.0 5.0 0.0)) "符号  尺   寸   形状   冲    针  数量" 2.5)
  34.   (t_ins (mapcar '+ p '(0.0 0.0 0.0)) es 2.3)
  35. )
求高手修改!!
 楼主| 发表于 2009-4-9 21:46:00 | 显示全部楼层
等待中.....
发表于 2009-4-9 22:53:00 | 显示全部楼层
没什么时间读你的程序,说具体的话帮你搞个
 楼主| 发表于 2009-4-10 21:33:00 | 显示全部楼层
就是把左边的文字统计成右边的.并写上序号!
发表于 2009-4-13 20:44:00 | 显示全部楼层
一样能实现,只是你提出的问题不是很详细
发表于 2009-4-15 15:06:00 | 显示全部楼层
期待高人~!
发表于 2009-6-29 16:51:00 | 显示全部楼层
ding上去
GMT+8, 2025-9-22 11:29 , Processed in 0.179542 second(s), 25 queries , Gzip On.
