查看: 895|回复: 2
[求助]请教高手,帮我看看这段程序,为何不起作用呢?
发表于 2009-3-28 09:15:00 | 显示全部楼层 |阅读模式
用途:把实体填充变成斜线填充.
(defun c:aa ( / e eee n ss)
(setq SS (ssget '((0 . "SOLID"))))
(if ss
    (setq n -1)
    (repeat (sslength SS)
       (setq eee (ssname  SS (setq n (+ n 1)))
    e (entget eee))
(setq e (subst (cons 100 "AcDbEntity") (assoc 100 e) e))
(setq e (subst (cons 100 "AcDbHatch") (assoc 100 e) e))
(setq e (subst (cons 0 "HATCH") (assoc 0 e) e))
(setq e (subst (cons 2 "ANSI31") (assoc 2 e) e))
(setq e (append e (list (cons 41 55))))
       (entmod e)
(PRINC "\n已更新完成!")
为何不起作用?
发表于 2009-3-28 09:27:00 | 显示全部楼层
"SOLID"和"HATCH"是两张不同的对象,组码参数相差很大
发表于 2009-3-28 09:34:00 | 显示全部楼层
这个海龙的工具箱估计也是......
如CAOYIN斑竹说的,2个组码参数错太多!
GMT+8, 2025-7-29 04:46 , Processed in 0.146181 second(s), 26 queries , Gzip On.
