查看: 1347|回复: 5
[求助]请教高手,帮我看看这段程序,为何出错呢?(已解决)
发表于 2009-3-28 22:21:00 | 显示全部楼层 |阅读模式
(defun MLA  (layname laycolor LayLine)
 (setq acadobject1   (vlax-get-acad-object)
       acaddocument1 (vla-get-activedocument acadobject1)
       mspace1         (vla-get-modelspace acaddocument1))
 (setq LayerSel (vla-get-Layers AcadDocument1))
 (setq LayerObj (vla-add LayerSel layname))
 (setq LineObj (vla-get-Linetypes AcadDocument1))
 (if (/= nil (tblsearch "layer" layname))
     (if (/= nil laycolor)
      (vla-put-color LayerObj laycolor)))
     (vla-get-activelayer AcadDocument1 LayerObj)
(if (/= nil LayLine)
(vla-put-Linetype LineObj LayLine)))
(vla-get-ActiveLinetype AcadDocument1 LayerObj)
 楼主| 发表于 2009-3-29 09:47:00 | 显示全部楼层
这是一个建立图层及线型的函数,哪个高手帮帮忙,改一下?
发表于 2009-3-29 10:32:00 | 显示全部楼层
您得先厘订这个语法错误....
 楼主| 发表于 2009-3-29 11:12:00 | 显示全部楼层
改了一下,还是不行呢?
(vla-put-Linetype LayerObj LayLine)
(vla-put-Linetype LayerObj LayLine))
发表于 2009-3-29 11:44:00 | 显示全部楼层
  1. ;(mla   "test"  25  "ACAD_ISO02W100")
  2. (defun MLA  (layname laycolor LayLine)
  3. (setq acadobject1   (vlax-get-acad-object)
  4.        acaddocument1 (vla-get-activedocument acadobject1)
  5.        mspace1         (vla-get-modelspace acaddocument1))
  6. (setq LayerSel (vla-get-Layers AcadDocument1))
  7. (setq LayerObj (vla-add LayerSel layname))
  8. (setq LineObj (vla-get-Linetypes AcadDocument1))
  9. (if (/= nil (tblsearch "layer" layname))
  10.   (progn
  11.      (if (/= nil laycolor)
  12.       (vla-put-color LayerObj laycolor)))
  13.   (progn
  14.      (vla-get-activelayer AcadDocument1 LayerObj)
  15.      (if (/= nil laycolor)
  16. (vla-put-color LayerObj laycolor))
  17. )
  18. )
  19. (if (/= nil LayLine)
  20. (progn
  21. (if (not (tblsearch "LTYPE" LayLine))
  22. (command "-linetype" "l" LayLine "acad.lin" "")
  23. )
  24. (vl-catch-all-apply 'vla-put-Linetype (list LayerObj LayLine))
  25. )
  26. (vla-put-Linetype LayerObj (vla-get-name (vla-get-ActiveLinetype AcadDocument1 )))
  27. )
  28. )
 楼主| 发表于 2009-3-29 13:14:00 | 显示全部楼层
谢谢xshrimp
GMT+8, 2025-7-29 04:56 , Processed in 0.152256 second(s), 26 queries , Gzip On.
