查看: 1314|回复: 4
请帮我查一下这段LISP问题出在哪(图),在线等!
发表于 2009-3-31 10:38:00 | 显示全部楼层 |阅读模式
请教高手:
我想要做到附件中图片(左)侧的要求,但是只做到图中(右)侧的程序,帮我分析一下问题到底出在哪?谢谢!
(defun c:t12()
   (setq cen1 (getpoint "\n中心点: "))
   (setq rr1 (getdist cen1 "\n大圆半径: "))
   (command "circle" cen1 rr1)
   (setq en1 (entlast))
   (command "circle" cen1 "d" rr1)
   (setq cen2 (polar cen1 0 rr1))
   (setq rr2 (getdist cen2 "\n小圆半径: "))
   (setq nn (getint "\n重复几次 <8>: "))
   (if (null nn) (setq nn 8))
   (setq ang 0 )
   (setq angdd (/ (* pi 2) nn))
   (repeat nn
     (command "circle" cen2 rr2)
     (setq en2 (entlast))
     (command "trim" en1 en2 "" (list en2 (polar cen1 ang (- rr1 rr2)))
       (list en1 cen2) "")
     (setq ang (+ ang angdd))
     (setq cen2 (polar cen1 ang rr1))
  (prin1)
发表于 2009-3-31 11:53:00 | 显示全部楼层
(defun C:T12 ()
  (setvar "OSMODE" 0)
  (setq CEN1 (getpoint "\n中心點: "))
  (setq RR1 (getdist CEN1 "\n大圓半徑: "))
  (command "circle" CEN1 RR1)
  (setq EN1 (entlast))
  (command "circle" CEN1 "d" RR1)
  (setq CEN2 (polar CEN1 0 RR1))
  (setq RR2 (getdist CEN2 "\n小圓半徑: "))
  (setq NN (getint "\n重複幾次 <8>: "))
  (if (null NN)
    (setq NN 8)
  (setq ANG 0)
  (setq ANGDD (/ (* pi 2) NN))
  (repeat NN
    (command "circle" CEN2 RR2)
    (setq EN2 (entlast))
    (command "trim"
      EN1
      EN2
      (list EN2 (polar CEN1 ANG (- RR1 RR2)))
      (list EN1 CEN2)
    (setq ANG (- ANG ANGDD))
    (setq CEN2 (polar CEN1 ANG RR1))
  (prin1)
 楼主| 发表于 2009-3-31 17:47:00 | 显示全部楼层
谢谢版主,可是为什么循环里  (setq ANG (- ANG ANGDD))是用减而不是用加呢?我的是按按顺时针画的,按道理来说不是一样的啊??
发表于 2009-4-1 08:01:00 | 显示全部楼层
當然不一樣,因trim的關係,保留下來的en1會有所改變
 楼主| 发表于 2009-4-1 09:24:00 | 显示全部楼层
我明白了,TRIM后,CAD是默认保留顺时钟方向的弧吗?谢谢版主~~
GMT+8, 2025-12-19 04:24 , Processed in 0.150181 second(s), 26 queries , Gzip On.
