查看: 2008|回复: 2
请教,还是选择集的问题
发表于 2003-6-9 17:49:00 | 显示全部楼层 |阅读模式
请教,要过滤出名为"LATE"的块,下面这段程序有什么问题吗?怎么过滤不出来,.COUNT老是0
        Point1 = ThisDrawing.Utility.GetPoint(, "Select the first point")
        point2 = ThisDrawing.Utility.GetCorner(Point1, "Select second point")
        BKCode(0) = 0
        BKDataValue(0) = "BLOCK"
        BKCode(1) = 2
        BKDataValue(1) = "LATE"
        myss.Select acSelectionSetWindow, Point1, point2, BKCode, BKDataValue
谢先!
发表于 2003-6-9 20:15:00 | 显示全部楼层
注意插入的块应该为“INSERT”,而不是block
 楼主| 发表于 2003-6-10 08:59:00 | 显示全部楼层
THANK YOU
THANK YOU VERY MUCH
GMT+8, 2025-5-24 03:16 , Processed in 0.148040 second(s), 23 queries , Gzip On.
