试试偶的这个 (defun C:ll () (setq olderr *error* *error* BZERR ) (princ "\n******画虚线******") (while t (setvar "cmdecho" 0) (setq pa (getpoint "\n 请指定虚线第一点:")) (setq pb (getpoint pa"\n 请指定下一点:")) (setq hh (distance pa pb)) (command "LINE" pa pb"") (if (<= hh 2 ) (command "change" (entlast) "" "p" "color" "252" "ltype" "DASHED2" "S" "1" "")) (if (> hh 2.000001 ) (command "change" (entlast) "" "p" "color" "252" "ltype" "DASHED2" "S" "2" "")) (if (> hh 5.00001 ) (command "change" (entlast) "" "p" "color" "252" "ltype" "DASHED2" "S" "5" "")) (if (> hh 30.0000 ) (command "change" (entlast) "" "p" "color" "252" "ltype" "DASHED2" "S" "10" "")) (if (> hh 50.000001 ) (command "change" (entlast) "" "p" "color" "252" "ltype" "DASHED2" "S" "15" "")) ;(if (> hh 90.000001 ) ;(command "change" (entlast) "" "p" "color" "252" "ltype" "DASHED2" "S" "30" "")) (princ "\n") ) (setq *error* olderr) (princ) ) ;;;;;;;;;;******************************** (defun C LL () (setq olderr *error* *error* BZERR ) (princ "\n******画中心线******") (while t (setvar "cmdecho" 0) (setq pa (getpoint "\n 请指定中心线第一点:")) (setq pb (getpoint pa"\n 请指定下一点:")) (setq hh (distance pa pb)) (command "LINE" pa pb"") (if (<= hh 10 ) (command "change" (entlast) "" "p" "color" "1" "ltype" "CENTER" "S" "1" "")) (if (> hh 10.000001 ) (command "change" (entlast) "" "p" "color" "1" "ltype" "CENTER" "S" "2" "")) (if (> hh 20.0000 ) (command "change" (entlast) "" "p" "color" "1" "ltype" "CENTER" "S" "5" "")) (if (> hh 50.000001 ) (command "change" (entlast) "" "p" "color" "1" "ltype" "CENTER" "S" "8" "")) (if (> hh 80.000001 ) (command "change" (entlast) "" "p" "color" "1" "ltype" "CENTER" "S" "12" "")) (princ "\n") ) (setq *error* olderr) (princ) ) |
