;仿照zdzdzdzd的新作。 ;;;********************************************** ;;; No.33 读取文本文件内容,并赋值给群变量 函数 ;;; ------ By Ayunger Studio 2009-4-18 ;;; 参数: SYMBase-变量前缀文字; ;;; IsView-是否屏幕浏览变量赋值情况表. ;;;********************************************** (defun ayGetTxtFile2Values(txtFileName SYMBase IsView / txtFileName fp xRec xNote xBar cName k i) (vl-load-com) (setq xBar "\n------------------------------------------------------------------------------") (if (and txtFileName (findfile txtFileName)) (progn (setq fp (open txtFileName "r")) (setq k 0) (while (setq xRec (read-line fp)) (set (read (strcat SYMBase (itoa (+ k 1)))) xRec) (setq k (+ k 1)) );end_while (close fp) (if (and IsView (> k 0)) (progn (textscr) (princ xBar) (setq i 1) (repeat k (setq cName (strcat SYMBase (itoa i))) (princ (strcat "\n[" cName "] " (eval (read cName)))) (setq i (+ i 1)) );end_preat (princ xBar) );end_progn );end_if (setq xNote (strcat (vl-filename-base txtFileName) (vl-filename-extension txtFileName))) (setq xNote (strcat "\n【信息】文本文件<" xNote ">的内容已读取至变量: ")) (setq xNote (strcat xNote SYMBase "1~" SYMBase (itoa k))) (princ xNote) );end_progn );end_if (princ) );end_defun
命令: (ayGetTxtFile2Values "c:/1.txt" "A" T) ------------------------------------------------------------------------------ [A1] 1.6 15 3 1.6 1.73 1.5 0.7 2.5--16 [A2] 2 16 3.8 2 1.73 1.5 1 3----20 [A3] 2.5 17 4.5 2.5 2.3 2 1.1 4----25 [A4] 3 18 5.5 3 2.87 2.5 1.3 5----30 [A5] 4 20 7 4 3.44 3 2 6----40 [A6] 5 22 8.5 5 4.58 4 2.5 8----50 [A7] 6 24 10 6 5.72 5 3 10----60 [A8] 8 28 13 8 6.86 6 4 12----80 [A9] 10 32 16 10 9.15 8 5 16---100 [A10] 12 36 18 12 11.43 10 6 20---120 [A11] 14 40 21 14 13.72 12 7 25---140 [A12] 16 44 24 16 16.00 14 8 25---160 [A13] 20 52 30 20 19.44 17 10 30---200 [A14] 24 60 36 24 21.73 19 12 40---200 [A15] 30 72 45 30 25.15 22 15.5 45---200 [A16] 36 84 54 36 30.85 27 19 55---200 [A17] 42 96 63 42 36.57 32 24 60---300 [A18] 48 106 72 48 41.13 36 28 70---300 ------------------------------------------------------------------------------ 【信息】文件 1.txt 内容已读取至变量: A1~A18   |
