查看: 1249|回复: 0
[转帖]转帖特定角度及长度捕捉的lsp,看看这个程序能否用,好像有点小毛病
发表于 2009-4-17 15:10:00 | 显示全部楼层 |阅读模式
特定角度及长度捕捉在AutoCAD中的实现方法
三、源程序清单
 ;; OS.LSP源程序
 ;;err(),出错处理子程序
 (defun err ( msg)
  (if (/= msg "Function cancelled")
  (princ(strcat "\nError:" msg)) ;打印错误内容
  ) ;for if
  (setq *error* olderr)
  (setvar "cmdecho" scmd)
  (setvar "osmode" cosmode)
  (setvar "coords" ccoords)
  (princ "n\n\t --多谢使用角度捕捉2.0版,程序非正常结束--!\n")
 ) ;for defun err
 ;; ant(),设定捕捉角度子程序
 (defun ant ( / ang0 ang1 )
  (setq ang0 (* an0 (/ 180 pi)) )
  (princ (strcat "\n请输入捕捉角度:<" (rtos ang0) ">_")) INITGET 4)
  (setq ang1 (getreal))
  (if (not (null ang1))
  (setq an0 (* ang1 (/ pi 180)))
  (princ "\n F2/F3/F4/F5/ESC/Return /下一点:")
 ) ;for defun ant
 ;; leng(),设定捕捉长度距离子程序
 (defun leng ( / leng0 leng1 )
  (setq leng0 len0)
  (princ (strcat "\n 请输入捕捉长度距离:<" (rtos leng0) ">_"))
  (INITGET 4)
  (setq leng1 (getreal))
  (if (not (null leng1))
  (setq len0 leng1 )
 ) ;for defun lent
 ;; field(),判断十字光标所在区间,并投影到相应的捕捉角度线上
 (defun field ( ps pe ang0 / ang1 n )
  (setq ang1 (angle ps pe))
  (setq n (fix (+ ( / ang1 ang0) 0.5)))
  (setq ang2 (* ang0 n))
 );for defun
 ;; endp(), 十字光标投影到相应的捕捉角度上后,以用户设定的长度
 ;; 捕捉计算落点
 (defun endp ( ps pe ang0 / p1 p2 p3 p4 dis )
  (setq p1 ps
  p2 (polar ps ang0 1)
  p3 pe
  p4 (polar pe (+ ang0 (/ pi 2)) 1)
  (setq pend (inters p1 p2 p3 p4 nil))
  (setq dis (distance ps pe))
  (if ( / = len0 0)
  (setq dist (* (fix (+ (/ dis len0) 0.5)) len0))
  ;else
  (setq dist dis)
  ) ;for if
  (setq pend (polar ps ang0 dist))
 ) ;for defun endp
 ;; drag(), 对上一次显示的拖曳线进行"或"操作,使其从屏幕上消失,
 ;; 并绘制下一次拖曳线
 (defun drag ( pold1 pold2 pold3 / )
  (if ( / = b2 4)
  (grdraw pold1 pold2 -1 0)
  (grdraw pold2 pold3 -1 0)
  ) ;for if
  (grdraw pstart pend -1 0)
  (grdraw pend pframe -1 0)
 ) ;for defun drag
 ;; coord(), 在屏幕的最上一行的坐标栏显示长度和角度
 (defun coord ( / str leng1 leng0 ang0)
  (setq ang0 (* ang2 (/ 180 pi)) )
  (setq str (strcat (rtos dist) ">" (rtos ang0)))
  (grtext -2 str)
 ) ;for defun coord
 ;; init(), 对程序进行初始化
 (defun init ( / )
  (setq scmd (getvar "cmdecho"));保留原命令回显方式
  (setq ccoords (getvar "coords"));保留原坐标显示方式
  (setq cosmode (getvar "osmode"))
  (setq olderr *error* *error* err) ;出错处理
  (setvar "cmdecho" 0);不回显
  (setvar "coords" 0) ;不显示坐标
  (setvar "osmode" 0 ) ;取消捕捉
  (setq b 0 b1 0 c '(0 0) )
  (setq pstart (getpoint "\n 请输入直线第一点:"))
  (if (or (null an0 ) (< an0 0) (not (numberp an0)))
  (setq an0 (/ pi 6))
  (ant)
  ) ; for if
  (if (or (null len0 ) (< len0 0) (not (numberp len0)))
  (setq len0 1)
  (leng)
  ) ;for if
  (if (null len0) (leng))
  (princ "\n F2/F3/F4/F5/ESC/Return /下一点::")
  (setq a (grread 2 nil))
  (setq pframe (cadr a))
  (field pstart pframe an0)
  (endp pstart pframe ang2)
  (setq plast pframe polde pend)
  (setq b (car a))
 ) ;for defun init
  ;; home(), 设置退出程序的控制变量
 (defun home ( / )
  (setq b 3)
  (setq b1 1)
 ) ;for defun home
 ;; pull(), 接受用户输入控制子程序
   (defun pull ( / )
 (setq b1 0)
 (while (/= b 3)
  (coord)
  (if (and (= b 2) (= b2 4)) (setq b 4))
  (setq b2 b)
  (setq b (car a))
  (cond
  ((or (= b 5) (= b 12) );只移动十字光标时
  (if (>= (distance plast pframe) 0.1)
  (drag pstart polde plast)
  ) ;for progn
  ) ;for if
  ) ;for progn
  ) ;for cond1
  ( (= b 3);用鼠标在屏幕上点取一点时
  (grdraw pstart polde -1 0)
  ) ;for progn
  ) ;for if
  ) ;for progn
  ) ;for cond1
  ((= b 2);键盘输入
  (setq c1 (cadr a))
  (cond ((= c1 138) (ant)) ;F2
  ((= c1 139) (leng)) ;F3
  ((= c1 140) ;F4
  (setq b2 4)
  (command"zoom" "0.7x")
  ) ;for (= c1 140)
  ((= c1 141) ;F5
  (setq b2 4)
  (command"zoom" "1.4x")
  ) ;for (= c1 141)
  ((= c1 13) (home))
  ((= c1 27) (home))
  (T (princ "\n 未定义的键"))
  ) ;for cond
  );for progn
  );for (cond (= b 2))
  ((= b 4);点取下拉菜单时
  (setq c1 (cadr a))
  (princ "\n")
  (cond ((= c1 6005)
  (command"zoom" "w")
  (princ "\n 第一角点:")
  (command pause)
  (princ "\n 第二角点:")
  (command pause)
  ) ;for (= c1 6005)
  ((= c1 6007)
  (command"zoom" "p" ))
  ((= c1 6008)
  (command"zoom" "a" ))
  ((= c1 6011)
  (command"pan")
  (princ "\n 第一参考点:")
  (command pause)
  (princ "\n 第二参考点:")
  command pause)
  ) ;for (= c1 6011)
  ;;else
  (T (princ "\n 未定义的菜单"))
  ) ;for cond
  ) ;FOR PROGN
  ) ;for (cond (= b 4))
  (T (home) ) ;for else
  ) ;for cond
  ) ;for progn
  ) ;for while
 ) ;for defun pull
 ;; draw() , 绘制直线子程序
 (defun draw ( / )
  (while (/= b1 1)
  (if (= b 3)
  (command"line" pstart pend "")
  (setq b 0 b1 1)
  (setq pstart pend)
  );for progn
  ); for if
  (pull)
  ) ;for progn
  ) ;for while
 ) ;for defun draw
 ;;;;主程序
 (defun c:os ( / b b1 b2 c pstart pend pframe plast ang2
  dist scmd ccoords olderr cosmode )
  ;;; an0 len0 are defined out program
 (init)
 (draw)
 (princ "\n")
 (command"redraw")
 (princ "\n\n\t ------角度捕捉2.0版------\n")
   (princ "\n\n\t**宁波大学建筑设计研究院--程建华,1996**\n")
 ) ;for defun os
本文来源于【天府教程】,原文链接:http://www.tfxy.com/pmdesign/2008/0412/article_2896.html
GMT+8, 2025-9-22 04:14 , Processed in 0.151343 second(s), 25 queries , Gzip On.
