查看: 1346|回复: 2
[求助]计划按对话框……知为什么却没反应了。(已解决)
发表于 2009-4-17 21:51:00 | 显示全部楼层 |阅读模式
  1. (defun show_dialog()
  2.   (setq f_id (open "d:/tmp.dcl" "w"))
  3.   (write-line "  mplot:dialog{" f_id)
  4.   (write-line "  label="测试";" f_id)
  5.   (write-line "   :button{" f_id)
  6.   (write-line "    label="确定";" f_id)
  7.   (write-line "    key="OK";" f_id)
  8.   (write-line "    action="(OK_Click)";" f_id)
  9.   (write-line "    is_default=true;" f_id)
  10.   (write-line "    width=8;" f_id)
  11.   (write-line "    fixed_width=true;" f_id)
  12.   (write-line "  }}" f_id)
  13.   (close f_id)
  14.
  15.   (setq dlg_id (load_dialog "d:/plotdialog.dcl"))
  16.   (new_dialog "mplot" dlg_id)
  17.   (start_dialog)
  18.   )
  19. (defun OK_click()
  20.   (command "-style" "mystyle" "仿宋_GB2312" "" "" "" "" "" )
  21.   )
请哪位高手看看,为什么这个一个[确定]CAD就死了。我用的是CAD2007
发表于 2009-4-17 21:55:00 | 显示全部楼层
运行dcl时不能执行command命令
 楼主| 发表于 2009-4-17 22:07:00 | 显示全部楼层
谢谢,解决了。
GMT+8, 2025-9-22 04:14 , Processed in 0.187586 second(s), 25 queries , Gzip On.
