查看: 1997|回复: 2
[求助]如何在为已有块添加属性后自动更新?
发表于 2009-4-17 21:54:00 | 显示全部楼层 |阅读模式
因工作需要
我想给一张图原有块添加相关属性
下面代码给名为TestBlock的块添加一个属性
Sub blockTest()
    Dim blockObj As AcadBlock
    Dim attObj As AcadAttribute
    Dim i As Integer
    ' Define the attribute definition
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim insertionPoint(0 To 2) As Double
    Dim tag As String
    Dim value As String
    height = 1#
    mode = acAttributeModeVerify
    prompt = "Attribute Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "Attribute Tag"
    value = "Attribute Value"
    ' Create the attribute definition object in model space
    For i = 3 To ThisDrawing.Blocks.Count - 1
        If (ThisDrawing.Blocks.Item(i).Name = "TestBlock") Then
            Set blockObj = ThisDrawing.Blocks.Item(i)
            Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
            attributeObj.Update
            Exit Sub
        End If
    Next i
End Sub
执行完上述代码后选中该块的一个块引用(block reference)查看其特性(properties)看不到刚添加的属性(Attribute)
如下图:
必须在“块属性管理器”中点“同步”后才行
请问如何才能用VBA实现为原有块添加属性后立即能从其块引用的特性(properties)里看到
即实现“块属性管理器”中点“同步”的功能??
多谢!!
发表于 2009-4-18 09:41:00 | 显示全部楼层
删掉块引用,重新插入一遍
 楼主| 发表于 2009-4-18 10:47:00 | 显示全部楼层
呵呵
多谢飞狐斑竹:)
我试下先
有没办法不重新插入就可以自动同步啊?
GMT+8, 2025-10-11 11:23 , Processed in 0.169453 second(s), 24 queries , Gzip On.
