查看: 1107|回复: 4
请教LISP问题
发表于 2009-4-24 20:03:00 | 显示全部楼层 |阅读模式
请教专家们:我编了这样一个倒直角的LISP程序,不过有3个疑问:
1、该程序执行过程出现一个错误,不知道为什么;
2、能否先执行倒角,后指定文字注记的位置和注记文字;
3、如何设置注记文字的样式。
谢谢!
lisp代码如下:
(defun C)
(setvar "cmdecho"0)
(while
(setq d(getstring"\n输入距离:"))
(setq pt(getpoint"\n指定文字注记位置:"))
(setq wz(strcat "D=" d "m"))
(command "text"pt "2" "" wz)
(setvar"chamfera" (atof d))
(setvar"chamferb" (atof d))
(command "chamfer")
princ
发表于 2009-4-25 15:17:00 | 显示全部楼层
(defun C:test()
(setq cmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq d (getstring"\n输入距离:"))
(while D
 (setq pt (getpoint"\n指定文字注记位置:"))
 (setq wz (strcat "D=" d "m"))
 (princ "\n请选择要倒角的实体:")
 (command "chamfer" pause pause)
 (setq d nil)
(setvar "cmdecho" cmd)
发表于 2009-4-25 15:19:00 | 显示全部楼层
(defun C:test()
(while D
 (command "text" pt "2" "" wz)
 (setq d nil)
发表于 2009-4-25 15:37:00 | 显示全部楼层
(if (not (tblsearch "style" "ST"))
 (command "style" "ST" "宋体" 0 1.0 0 "N" "N")
(command "text" "S" "ST" pt "2" "" wz)
 楼主| 发表于 2009-4-26 21:48:00 | 显示全部楼层
非常感谢!
GMT+8, 2025-9-22 04:56 , Processed in 0.165163 second(s), 25 queries , Gzip On.
