查看: 2081|回复: 1
vba调用lsp涉及到的"""和chr(34)的用法
发表于 2009-4-28 13:55:00 | 显示全部楼层 |阅读模式
在VBA中,直接写(command "Stretch" "c" pause pause "")不成立。
例如语句中的"Stretch" 等价写法是chr(34) & "Stretch" & chr(34)
           也可以等价写法"""Stretch"""  ,"""在CAD命令行中得到的结果为一个双引号"
Sub ls()
  With ThisDrawing
    .SendCommand "(command " & """Stretch""" & " ""c"" " & "pause pause " & """""" & ")"
  End With
End Sub
程序运行结果等价LISP在CAD命令行中的
 楼主| 发表于 2009-4-28 15:47:00 | 显示全部楼层
扩展使用
  1. Sub ls1()
  2.   With ThisDrawing
  3.      Dim Ent  As AcadDimension
  4.    Dim kwordList As String
  5.     kwordList = "Up Down Left Right"
  6.     .Utility.InitializeUserInput 1, kwordList
  7.     Dim returnString As String
  8.     returnString = .Utility.GetKeyword("Enter a keyword (Up)(Down)(Left)(Right): ")
  9.
  10.     Dim objDim As AcadDimRotated
  11.     .Utility.GetEntity objDim, pt, "ddd"
  12.
  13.     Debug.Print returnString
  14.     With objDim
  15.       tt = Abs(.Measurement - .TextOverride)
  16.       Select Case returnString
  17.         Case "Up"
  18.           tt = "@0," & tt
  19.         Case "Down"
  20.           tt = "@0,-" & tt
  21.         Case "Left"
  22.           tt = "@-" & tt & ",0"
  23.         Case "Right"
  24.           tt = "@" & tt & ",0"
  25.       End Select
  26.
  27.       .TextOverride = ""
  28.     End With
  29.     .SendCommand "(setq ee " & Chr(34) & tt & Chr(34) & ")" & vbCr
  30.     '.SendCommand "(command " & """Stretch""" & " ""c"" " & "pause pause " & """""" & " pause " & """""" & " ee)" & vbCr
  31.     .SendCommand "(command " & """Stretch""" & " ""c"" " & "pause pause " & """""" & " pause ee)" & vbCr
  32.    End With
  33. End Sub
GMT+8, 2025-4-30 23:25 , Processed in 0.198129 second(s), 24 queries , Gzip On.
