查看: 1198|回复: 2
请教主程序与子程序之间调用返回值的问题
发表于 2009-4-28 14:11:00 | 显示全部楼层 |阅读模式
请教下面主程序与子程序之间调用返回值的问题
(defun c:hf_stru()
(setvar "cmdecho" 0)
(setq ffn (getfiled "选择文件"  "" "sat" 2))
(setq ff (open ffn "r"))
(setq data (read-line ff))
(while data
       (if (= data "C_____ NST   nSect  nNodeBase   nNodeDisp  nNodeElas")
                 (setq jgcs data)
                 (setq zf " ")
                 (hf_szf jgcs zf)
(close ff)
(prin1)
(defun hf_szf (jgcs zf)
(setq zfcd (strlen jgcs))
(setq i 1)
(setq zfcdn zfcd)
(repeat zfcd
    (if (= (substr jgcs i 1) zf)
           (cond
             ((= i 1) (setq jgcs (substr jgcs 2)))
             ((= i zfcdn) (setq jgcs (substr jgcs 1 (- zfcdn 1))))
             (t (setq jgcs (strcat (substr jgcs 1 (- i 1)) (substr jgcs (+ i 1)))))
           (setq zfcdn (strlen jgcs))
        (setq i (1+ i))
jgcs
 楼主| 发表于 2009-4-28 14:12:00 | 显示全部楼层
不知道哪里错了,我要返回jgcs值
发表于 2009-4-28 15:51:00 | 显示全部楼层
(setq yourvar (hf_szf jgcs zf))
GMT+8, 2025-9-22 04:56 , Processed in 0.150265 second(s), 25 queries , Gzip On.
