查看: 1863|回复: 4
[求助]高手们帮忙看下以下源码,我想按空格键退出WHILE循环,该如何做
发表于 2009-4-28 22:08:00 | 显示全部楼层 |阅读模式
(defun c:plgj ()
(setq sn (entsel "\n选择文字"))
(setq sb (car sn)
p1 (cadr sn)
txtbasepoint (cdr (assoc 10 (entget sb)))
p2 t
i 1
(while (and (< i 9) p2)
(command "copy" sb "" txtbasepoint pause "")
(setq txt (entlast)
txt_list (entget txt)
txtbasepoint (cdr (assoc 10 txt_list))
(setq sb txt)
(setq old_wbnr_list (assoc 1 txt_list))
(cond ((= i 1) (setq new_wbnr_list (cons 1 "DN25")))
((or (= i 3) (= i 2)) (setq new_wbnr_list (cons 1 "DN32")))
((= i 4) (setq new_wbnr_list (cons 1 "DN40")))
((and (>= i 5) (<= i 8))
(setq new_wbnr_list (cons 1 "DN50"))
(setq txt_list (subst new_wbnr_list old_wbnr_list txt_list))
(entmod txt_list)
(setq i (1+ i))
发表于 2009-4-29 08:29:00 | 显示全部楼层
...我想按空格键退出WHILE循环....
您得将 按空格键 的返回值加入 (and ....) 的判断式中
但看不到您有对 按空格键 取值 / 且在何处取值 ?
 楼主| 发表于 2009-4-29 09:11:00 | 显示全部楼层
麻烦您告知一下,如何 按空格键 取值 / 且在何处取值 。我的思路是这样的,按上面的程序,必须循环八次才能退出。但是我有时候需要循环的次数小于八次,因此我想在达到需要循环的次数后,按空格键退出循环。
发表于 2009-4-29 09:36:00 | 显示全部楼层
问题是您并未 对 按空格键 取值 建立管道呀
发表于 2009-4-29 22:16:00 | 显示全部楼层
;读取点坐标,输入两参数到e:/temp.csv----v1.0
(defun c:readid()
(setq temp (open "e:/temp.csv" "a"))
(princ "\n\n" temp)
(setq char "a") ;初始化char,必须地
(while (/= char "b")
  (setq p1 (getpoint "\n选择点:"))
  (setq z1 (getreal "\n输入参数1的值:"))
  (setq z2 (getreal "\n输入参数2的值:"))
  (princ (strcat  (rtos (car p1) 2) "," (rtos (cadr p1) 2) ","  (rtos z1 2) ","  (rtos z2 2) "\n" ) temp)
  (setq char (getstring "继续(anykey)/中止(Break):"))  ;输入b退出循环
  (close temp)
看上面的循环,把B改成空格即成,把条件表达式or进去
GMT+8, 2025-9-22 04:57 , Processed in 0.168671 second(s), 26 queries , Gzip On.
