(defun initimg( img_key slide / x1 y1) // 定义初始化函数,有两个全局变量img_key和slide (setq x1 (dimx_tile img_key)) //获取图像按钮的长度 (setq y1 (dimy_tile img_key)) //获取图像按钮的宽度 (start_image img_key)//开始图像控件的生成 (slide_image -3 -30 x1 y1 slide) //在激活对话框图像控件上显示一个幻灯片 (end_image) //结束图像处理函数 ) (defun img (/ id ) (setq id (load_dialog "e:\\lisp\\zijide")) //装载对话框文件 (if (< id 0) (exit)) //如文件不存在,退出 (if (not (new_dialog "jingujian" id)) (exit)) //对话框文件中名称不存在,退出 (initimg "screw_0" "e:\\lisp\\GBT799-1988") //调用初始化函数 screw_0为图像按钮key,e:\\autolisp study\\circ为幻灯片 (initimg "screw_1" "e:\\lisp\\GBT6181-1986") (initimg "screw_2" "e:\\lisp\\GBT9458-1988") (initimg "screw_3" "e:\\lisp\\GBT9458-1989") (initimg "screw_4" "e:\\lisp\\JBZQ4321-1986") (initimg "screw_5" "e:\\lisp\\GBT9459-1988") (setq what_value 4) (action_tile "screw_0" "(mn01 id)") //按GBT799-1988图像按钮,显示其子对话框,id为传递 参数,必须 保证在new_dialog后 (action_tile "screw_1" "(mn02 id)") (action_tile "screw_2" "(mn03 id)") (action_tile "screw_3" "(mn04 id)") (action_tile "screw_4" "(mn05 id)") (action_tile "screw_5" "(mn06 id)") (action_tile "accept" "(done_dialog 1)")//设置变量 (action_tile "cancel" "(done_dialog 0)") (setq what_value (start_dialog))//激活对话框 (princ) (unload_dialog id) //卸载对话框 (princ) ) (defun mn01 ( id) //显示子circ子对话框 draw_circ是qiantao_main对话框文件中子对话框的名称 (if (not (new_dialog "draw_dijiao01" id)) (exit)) (setq d 0 l 0 )//设置编辑框初值变量 (set_tile "s_d" (rtos X 2 2))//设置初值 set_tile是设置关键字key控件的值,rtos将数转换为string 2表示十进制 2表示小数点后两位 (set_tile "s_l" (rtos Y 2 2)) (action_tile "accept" "(getdata1)(done_dialog 2)") (action_tile "cancel" "(done_dialog 3)") (setq what_next (start_dialog)) ) (defun mn02 ( id) //显示子circ子对话框 draw_circ是qiantao_main对话框文件中子对话框的名称 (if (not (new_dialog "draw_GBT6181_1986" id)) (exit)) (setq m 0 )//设置编辑框初值变量 (set_tile "s_d" (rtos X 2 2))//设置初值 set_tile是设置关键字key控件的值,rtos将数转换为string 2表示十进制 2表示小数点后两位 (action_tile "accept" "(getdata1)(done_dialog 4)") (action_tile "cancel" "(done_dialog 5)") (setq what_next (start_dialog)) ) (defun mn03 ( id) //显示子circ子对话框 draw_circ是qiantao_main对话框文件中子对话框的名称 (if (not (new_dialog "draw_GBT9458-1988" id)) (exit)) (setq m 0 )//设置编辑框初值变量 (set_tile "s_d" (rtos X 2 2))//设置初值 set_tile是设置关键字key控件的值,rtos将数转换为string 2表示十进制 2表示小数点后两位 (action_tile "accept" "(getdata1)(done_dialog 6)") (action_tile "cancel" "(done_dialog 7)") (setq what_next (start_dialog)) ) (defun mn04 ( id) //显示子circ子对话框 draw_circ是qiantao_main对话框文件中子对话框的名称 (if (not (new_dialog "draw_dijiao02" id)) (exit)) (setq m 0 )//设置编辑框初值变量 (set_tile "s_d" (rtos X 2 2))//设置初值 set_tile是设置关键字key控件的值,rtos将数转换为string 2表示十进制 2表示小数点后两位 (action_tile "accept" "(getdata1)(done_dialog 8)") (action_tile "cancel" "(done_dialog 9)") (setq what_next (start_dialog)) ) (defun mn05 ( id) //显示子circ子对话框 draw_circ是qiantao_main对话框文件中子对话框的名称 (if (not (new_dialog "draw_GBT9459-1988" id)) (exit)) (setq m 0 )//设置编辑框初值变量 (set_tile "s_d" (rtos X 2 2))//设置初值 set_tile是设置关键字key控件的值,rtos将数转换为string 2表示十进制 2表示小数点后两位 (action_tile "accept" "(getdata1)(done_dialog 10)") (action_tile "cancel" "(done_dialog 11)") (setq what_next (start_dialog)) ) (defun mn06 ( id) //显示子circ子对话框 draw_circ是qiantao_main对话框文件中子对话框的名称 (if (not (new_dialog "draw_JBZQ4321-1986" id)) (exit)) (setq m 0 )//设置编辑框初值变量 (set_tile "s_d" (rtos X 2 2))//设置初值 set_tile是设置关键字key控件的值,rtos将数转换为string 2表示十进制 2表示小数点后两位 (action_tile "accept" "(getdata1)(done_dialog 12)") (action_tile "cancel" "(done_dialog 13)") (setq what_next (start_dialog)) ) jingujian:dialog{ label="紧固件类型的选择"; :row{ :boxed_column{ label="选择类型"; :row{ :image_button{//图像按钮0 color=-2;width=30;aspect_ratio=1;key="screw_0"; } :image_button{//图像按钮1 color=-2;width=30;aspect_ratio=1;key="screw_1"; } :image_button{//图像按钮2 color=-2;width=30;aspect_ratio=1;key="screw_2"; } } :row{ :image_button{//图像按钮3 color=-2;width=30;aspect_ratio=1;key="screw_3"; } :image_button{//图像按钮4 color=-2;width=30;aspect_ratio=1;key="screw_4"; } :image_button{//图像按钮5 color=-2;width=30;aspect_ratio=1;key="screw_5"; } } } } :row{//继续和退出按钮 spacer_1; :button{ label="继续";key="accept";is_default=true;fixed_width=true; } :button{ label="退出";key="cancel";fixed_width=true; } spacer_1; } } draw_U:dialog{//子对话框 label="确定U型螺栓参数"; :row{//第一行:1个图像和两个列表 :image{color=-2;width=30;aspect_ratio=0.8;key="id_img";}//图像 :list_box{label="管子外径&D0";key="s_d";edit_width=5;height=8; list="14\n18\n22\n25\n33\n38\n42\n45\n48\n51\n57\n60\n76\n83\n89\n102\n108\n114\n133\n140\n159\n165\n219\n"; fixed_width=true;}//大径列表 }//第一行结束 :row{//第二行,有两列 :column{ :boxed_column{label="定位点"; :edit_box{label="定位点&x坐标";key="p_x";edit_box=10;value="150";} :edit_box{label="定位点&y坐标";key="p_y";edit_box=10;value="100";} :button{label="光标拾取<";key="p_p";} } ok_cancel; } } } draw_dijiao01:dialog{//子对话框 label="确定地脚螺栓的参数"; :row{//第一行:1个图像和两个列表 :image{color=-2;width=22;aspect_ratio=0.5;key="id_img";}//图像 :list_box{label="&d";key="s_d";edit_width=5;height=8; list="M6\nM8\nM10\nM3\nM12\nM16\nM20\nM24\nM30\nM36\nM42\nM48\n"; fixed_width=true;}//大径列表 :list_box{label="公称长度&l";key="s_l";edit_width=5;height=8; list="400\n500\n630\n800\n1000\n1250\n1500\n"; fixed_width=true;}//长度列表 }//第一行结束 :row{//第二行,有两列 :column{ :boxed_column{label="定位点"; :edit_box{label="定位点&x坐标";key="p_x";edit_box=8;value="150";} :edit_box{label="定位点&y坐标";key="p_y";edit_box=8;value="100";} :button{label="光标拾取<";key="p_p";} } ok_cancel; } } } draw_GBT9458_1988:dialog{//子对话框 label="确定螺母的参数"; :row{//第一行:1个图像和两个列表 :image{color=-2;width=22;aspect_ratio=0.5;key="id_img";}//图像 :list_box{label="螺纹规格&m";key="s_d";edit_width=5;height=8; list="M5\nM6\nM8\nM10\nM12\nM14\nM16\nM18\nM20\nM22\nM24\nM27\nM30\nM33\nM36\n"; fixed_width=true;}//大径列表 }//第一行结束 :row{//第二行,有两列 :column{ :boxed_column{label="定位点"; :edit_box{label="定位点&x坐标";key="p_x";edit_box=8;value="150";} :edit_box{label="定位点&y坐标";key="p_y";edit_box=8;value="100";} :button{label="光标拾取<";key="p_p";} } ok_cancel; } } } draw_GBT6181_1986:dialog{//子对话框 label="确定螺母的参数"; :row{//第一行:1个图像和两个列表 :image{color=-2;width=22;aspect_ratio=0.5;key="id_img";}//图像 :list_box{label="螺纹规格&d";key="s_d";edit_width=5;height=8; list="M5\nM6\nM8\nM10\nM12\nM14\nM16\nM18\nM20\nM22\nM24\nM27\nM30\nM33\nM36\n"; fixed_width=true;}//大径列表 }//第一行结束 :row{//第二行,有两列 :column{ :boxed_column{label="定位点"; :edit_box{label="定位点&x坐标";key="p_x";edit_box=8;value="150";} :edit_box{label="定位点&y坐标";key="p_y";edit_box=8;value="100";} :button{label="光标拾取<";key="p_p";} } ok_cancel; } } } draw_GBT9459_1988:dialog{//子对话框 label="确定螺母的参数"; :row{//第一行:1个图像和两个列表 :image{color=-2;width=22;aspect_ratio=0.5;key="id_img";}//图像 :list_box{label="螺钉大径&d";key="s_d";edit_width=5;height=8; list="M5\nM6\nM8\nM10\nM12\nM14\nM16\nM18\nM20\nM22\nM24\nM27\nM30\nM33\nM36\n"; fixed_width=true;}//大径列表 }//第一行结束 :row{//第二行,有两列 :column{ :boxed_column{label="定位点"; :edit_box{label="定位点&x坐标";key="p_x";edit_box=8;value="150";} :edit_box{label="定位点&y坐标";key="p_y";edit_box=8;value="100";} :button{label="光标拾取<";key="p_p";} } ok_cancel; } } } draw_dijiao02:dialog{//子对话框 label="确定地脚螺栓的参数"; :row{//第一行:1个图像和两个列表 :image{color=-2;width=22;aspect_ratio=0.5;key="id_img";}//图像 :list_box{label="螺钉大径&d";key="s_d";edit_width=5;height=8; list="M1.6\nM2\nM2.5\nM3\nM4\nM5\nM6\nM8\nM10\nM12\nM14\nM16\nM20"; fixed_width=true;}//大径列表 :list_box{label="螺钉长度&l";key="s_l";edit_width=5;height=8; list="2\n2.5\n3\n4\n5\n6\n8\n10\n12\n(14)\n16\n20\n25\n30\n35\n40\n45\n50\n"; fixed_width=true;}//长度列表 }//第一行结束 :row{//第二行,有两列 :column{ :boxed_column{label="定位点"; :edit_box{label="定位点&x坐标";key="p_x";edit_box=8;value="150";} :edit_box{label="定位点&y坐标";key="p_y";edit_box=8;value="100";} :button{label="光标拾取<";key="p_p";} } ok_cancel; } } } 谢谢了 |
