查看: 1302|回复: 2
[求助]修改文字内容,出现参数错误!
发表于 2009-5-4 11:10:00 | 显示全部楼层 |阅读模式
(defun c:gz(/)
  (setq sel (ssget "x" '((0 . "text"))))
    (SETQ STGS (SSLENGTH SEL))
    (SETQ I 0)
    (REPEAT STGS
 (SETQ STNAME (SSNAME SEL I))
 (SETQ ST (ENTGET STNAME))
 (SETQ point1 (ASSOC 1 ST))
 (SETQ z1 (cdr point1) z2 (atof z1) z2 (+ z2 10.02))
        (setq z3 (rtos z2 2 2))
 (setq point1 (subst z3 (cdr point1) point1));在此提示参数类型错误
 (SETQ ST (SUBST point1 (ASSOC 1 ST) ST ))
 (ENTMOD ST)
 (SETQ I (+ I 1))
谢谢
发表于 2009-5-4 11:41:00 | 显示全部楼层
  1. (defun c:gz(/)
  2. (setq sel (ssget "x" '((0 . "text"))))
  3. (SETQ STGS (SSLENGTH SEL))
  4. (SETQ I 0)
  5. (REPEAT STGS
  6.   (SETQ STNAME (SSNAME SEL I))
  7.   (SETQ ST (ENTGET STNAME))
  8.   (SETQ point1 (ASSOC 1 ST))
  9.   (SETQ z1 (cdr point1) z2 (atof z1) z2 (+ z2 10.02))
  10.   (setq z3 (rtos z2 2 2))
  11.   (setq st (subst (cons 1 z3) point1 st))
  12.   (ENTMOD ST)
  13.   (SETQ I (+ I 1))
  14. )
  15. (princ)
  16. )
 楼主| 发表于 2009-5-4 13:37:00 | 显示全部楼层
谢谢斑竹
GMT+8, 2025-10-18 06:52 , Processed in 0.165184 second(s), 25 queries , Gzip On.
