查看: 42812|回复: 95
[源码] [原创]标注对齐源程序
发表于 2009-5-5 22:08:00 | 显示全部楼层 |阅读模式
根据网友建议修改更新于2010年12月31日。(网上有个某老大做的尺寸标注对齐的源程序,但是在对齐尺寸时,尺寸界线也发生移动。本人编写了一个尺寸标注对齐的程序,在对齐时候尺寸界线不移动,可能效果好一些,请大家试用。在明经里边学到很多东西,自己也献献丑,做的东西分享给大家。)
坐标的我已经发过一个,请参考http://bbs.mjtd.com/thread-78807-1-1.html
;;; _______________________________________________________;;; 标注对齐     langjs 2011.11.26
;;; (本程序仅适用于多个水平或垂直标注对齐)
(defun c:qq (/ ent i name np10 np11 np13 np14 p0 p00 p10 p11 p13 p14 ss ss1 ss2 u v)
  (defun ssgengxin (ss / ent i name p10 p14 ss1 ss2) ; 将误选的横纵标注(少数量)从选择集中删除?
    (setq ss1 (ssadd)  ss2 (ssadd))
    (repeat (setq i (sslength ss))
      (setq ent (entget (setq name (ssname ss (setq i (1- i)))))
            p10 (cdr (assoc 10 ent))  p14 (cdr (assoc 14 ent))
      (cond
        ((= (fix (+ 0.5 (car p10))) (fix (+ 0.5 (car p14))))
          (setq ss1 (ssadd name ss1))
        ((= (fix (+ 0.5 (cadr p10))) (fix (+ 0.5 (cadr p14))))
          (setq ss2 (ssadd name ss2))
        (t )
    (if (>= (sslength ss1) (sslength ss2))  ss1  ss2 )
  (defun jisuan (ent / p10 p11 p13 p14)        ; 计算坐标点子程序
    (setq p10 (cdr (assoc 10 ent))  p14 (cdr (assoc 14 ent))
          p11 (cdr (assoc 11 ent))  p13 (cdr (assoc 13 ent))
    (cond
        (setq np10 (list (car p10) (cadr p0))
              np11 (list (car p11) (+ (- (cadr p11) (cadr p10)) (cadr p0)))
              np13 (list (car p13) (cadr p00))
              np14 (list (car p14) (cadr p00))
        (setq np10 (list (car p0) (cadr p10))
              np11 (list (+ (- (car p11) (car p10)) (car p0)) (cadr p11))
              np13 (list (car p00) (cadr p13))
              np14 (list (car p00) (cadr p14))
  (defun gengxin (ent u np10 v np11)
    (setq ent (subst(cons u np10)(assoc u ent) ent ))
    (entmod (subst  (cons v np11)(assoc v ent) ent ))
  (setvar "cmdecho" 0)                       ; 关闭命令响应
  (if (setq ss (ssget '((0 . "DIMENSION"))))
      (setq ss (ssgengxin ss))
      (if (setq p0 (getpoint "\n指定标注线位置,或<不改变>:"))
          (setq ent (entget (ssname ss (setq i (1- i)))))
          (jisuan ent)
          (gengxin ent 10 np10 11 np11)
        (setq p0 '(0.0 0.0))
      (if (setq p00 (getpoint "\n指定引出线位置,或<不改变>:"))
          (jisuan ent)
          (gengxin ent 13 np13 14 np14)
参与人数 5威望 +1 明经币 +3 金钱 +40 收起 理由
断箭 + 1 很给力!
cabinsummer + 1 很给力!
T_T + 20 好用!谢谢
raimo + 20 好程序,感谢您的分享
mccad + 1 + 1 【好评】日常管理
本帖被以下淘专辑推荐:
发表于 2010-12-8 07:46:46 | 显示全部楼层
真的很好用
发表于 2017-10-28 12:53:52 | 显示全部楼层
射手座的牛 发表于 2013-1-24 22:30
(defun c:dd ()
(while
  (setq pt1 (getpoint "\n指定第一条尺寸界线原点:"))
解决我多年的角度标注的困惑,谢谢你!
发表于 2009-5-6 08:52:00 | 显示全部楼层
學習啦
好貼
发表于 2009-5-6 10:02:00 | 显示全部楼层
谢谢了。
发表于 2009-5-6 11:11:00 | 显示全部楼层
你好,能否开发一个坐标标注对齐的工具,谢谢
发表于 2009-5-15 16:15:00 | 显示全部楼层
好程序,谢谢
发表于 2009-5-18 00:45:00 | 显示全部楼层
不错,不用单个进行调整了
发表于 2009-10-19 19:37:00 | 显示全部楼层
这是好东西呀,高手呀楼主
发表于 2009-11-15 20:49:00 | 显示全部楼层
程序写得不错,顶一个,,
发表于 2009-11-16 20:23:00 | 显示全部楼层
真的很好用,如果有座标的就更好了。
发表于 2009-11-22 13:56:00 | 显示全部楼层
赞一个
GMT+8, 2025-12-13 04:26 , Processed in 0.200901 second(s), 35 queries , Gzip On.
