查看: 20574|回复: 33
[求助(已解决)]用lisp读取Excel文件中指定单元格的数据
发表于 2009-5-7 16:11:00 | 显示全部楼层 |阅读模式
通过在明经、晓东里边转了一圈又一圈之后终于能从Excel里边把单元格的数据读出来了。但是,还有个大问题解决不了:
1.
(vla-put-visible xlapp 1);1-可见,0-隐藏
这一句把所有打开的Excel文件都给隐藏掉了!!!!!
2.同样的
(vlax-invoke-method xlapp 'quit)
这一句把所有打开的Excel文件都给关掉了!!!!!!!!!!!!
如何处理,能够让我可以把数据读出来且不影响其它打开的Excel文件?或者这么说:是否可以不打开指定的Excel文件就能将其中的数据读出来?
各位大神给伸伸手指点下吧,谢谢啦……
(defun excel-get-data (/ xlapp xlfile fn H8)
  (vl-load-com)
  ;读取单元格数据
  (defun Excel-Get-CellValue(xlapp cell / xlsrng xlsval)
    (setq xlsrng (vlax-get-property xlapp "range" cell))
    (setq xlsval (vlax-variant-value (vlax-get-property xlsrng "Value")))
  (setq xfile (getfiled "打开法兰计算文件" "" "xls" 8))
  (if (setq fn (findfile xfile))
    (if (setq xlapp (vlax-get-or-create-object "Excel.Application"))
 (vlax-invoke-method
   (vlax-get-property xlapp 'WorkBooks)
   'Open
   fn
 (vla-put-visible xlapp 0);1-可见,0-隐藏
 ;单元格数据读取
 (setq H8 (Excel-Get-CellValue xlapp "H8"))
 ;退出并关闭Excel进程
 (vlax-release-object xlapp)
  H8
问题已解决
下面是测试的程序:
;;;取出Excel文件中第一个工作表中指定单元格的数据
(defun c:ttt ()
  (Excel-Get-data)
(defun Excel-Get-data ( / xfile cell ADOCONNECT ADORECORDSET ConnectionString lst Sheet-name source cell-tmp cell-value)
  ;指定单元格的数据
  (defun Excel-Get-CellValue (Sheet-name cell)
    (setq source (strcat "SELECT * FROM [" Sheet-name cell":" cell "]"))
    (vlax-invoke-method  ADORecordset "Open" source ADOConnect 1 3 nil)
    (setq cell-tmp (vlax-safearray->list (vlax-variant-value (vlax-invoke-method ADORecordset "GetRows" 1))))
    (vlax-variant-value (car (car cell-tmp)))
  (setq ADOConnect (vlax-get-or-create-object "ADODB.Connection"))
  (setq ADORecordset (vlax-get-or-create-object "ADODB.Recordset"))
  (setq ConnectionString (strcat "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" xfile ";Extended Properties=;Excel 8.0;HDR=No" ))
  (if (not
 (vl-catch-all-error-p
   (vl-catch-all-apply
     (function vlax-invoke-method)
     (list ADOConnect "Open" ConnectionString  "admin" "" nil)
      (setq lst
        (vlax-variant-value
   (vlax-invoke-method (vlax-invoke-method ADOConnect "OpenSchema" 4 ) "GetRows" 1)
      (setq Sheet-name (vlax-variant-value (car (caddr lst))));确定"第一个"工作表的名称
      (setq cell-value (Excel-Get-CellValue Sheet-name "H16"));H16单元格
      (vlax-invoke-method ADORecordset "Close")
      (vlax-invoke-method ADOConnect "Close")
      (princ "\n打开Excel数据文件出错")
      (vl-catch-all-apply 'vlax-invoke-method (list ADOConnect "Close"))
      (setq cell-value nil)
  (vlax-release-object ADORecordset)
  (vlax-release-object ADOConnect)
  cell-value
不用ADO原来也是可以实现的
 ;退出并关闭Excel进程
上边两句改成以下内容即可
;退出并关闭Excel文件
 (vlax-invoke-method
   (vlax-get-property xlapp 'ActiveWorkbook)
   'close
 楼主| 发表于 2009-5-17 14:33:00 | 显示全部楼层
lkt209发表于2009-5-15 13:08:00注意隐藏的不是xlapp这是程序对象隐藏的是xfile打开的文件对象搞错了!
xfile为lisp下的文件名,怎么变成vl对象?
PS:感谢lzh741206版主
另,参照http://www.mjtd.com/bbs/dispbbs.asp?boardid=3&replyid=567&id=73343&page=1&skin=0&landlord=0&Star=2处的程序,我已经基本上写好我需要的“不打开指定的Excel文件就能将其中指定单元格的数据读出来”,程序在一楼,有兴趣的朋友可以去看看。
发表于 2022-7-11 16:00:46 | 显示全部楼层
  1. [code=lisp](defun Excel:ReadRange (range / array) (setq value (vlax-get-property range 'Value2)) (if (= (vlax-variant-type value) 8204) (mapcar '(lambda (x) (mapcar 'vlax-variant-value x)) (vlax-safearray->list (vlax-variant-value value)) ) (vlax-variant-value value) ) )
[/code]
发表于 2009-5-7 21:35:00 | 显示全部楼层
(SETQ AA(msxl-GET-value1
 (msxl-get-range *XLAPP*  "A1")
(vlax-variant-value AA)
提取A1单元格的数据
 楼主| 发表于 2009-5-7 23:18:00 | 显示全部楼层
能给出完整程序么?
msxl-GET-value1,这个函数貌似加载不了
 楼主| 发表于 2009-5-8 08:18:00 | 显示全部楼层
把二楼的程序修改了一下,可以执行了。本质上这个和http://www.mjtd.com/Develop/ArticleShow.asp?ArticleID=667 的程序是一样的,具体表现形式和我一楼的程序也是一样的。还是做不到“不打开指定的Excel文件就能将其中的数据读出来”。还请高手们指点指点。
(defun Excel-Get-CellValue (xlapp cell /)
    (vlax-variant-value (msxl-GET-value (msxl-get-range xlapp  cell)))
发表于 2009-5-8 12:01:00 | 显示全部楼层
乍有可能不打开文件就能读取数据了?
谁都不能做的的!只是看你如何打开而已吧?
原来的excel程序是打开的,你就不要quit!
原来的文档是打开的你就不要close!
否则,就该乍的就乍的!这不就实现了不影响其它打开的Excel文件!
 楼主| 发表于 2009-5-8 13:02:00 | 显示全部楼层
咋就木有可能呢?
自己做不到不代表谁都做不到的,不然为啥上明经来问呢,不就是因为咱明经高人多么!
原来的文档不要close,我现在就是这么做的。
但是,做程序不就是要追求完美一些么?
老想着让用户该乍的就乍的,不再程序上下功夫是要不得的!!!!!!!
发表于 2009-5-8 13:36:00 | 显示全部楼层
如果楼主会VBA可以测试一下,VBA不用EXCEL.APPLICATION而是直接调用里的WORKSHEETS等对象,但只要调用了EXCEL类里的东西,就可以在任务管理器里看到EXCEL.EXE进程,所以如果不打开EXCEL文件而读取里面的内容应该是不可能的。
不过好像可以用数据库的SQL语句调用EXCEL数据库。具体怎么做就不是很清楚了。
 楼主| 发表于 2009-5-9 00:24:00 | 显示全部楼层
那就是说,应该还是有可能不打开EXCEL文件而读取里面的内容的~!只是会的人现在还没看到我的帖子罢了
发表于 2009-5-9 12:43:00 | 显示全部楼层
顶出个高手出来!
发表于 2009-5-9 13:05:00 | 显示全部楼层
不打开当然读写不了数据,只是可以打开但不显示,表面上是不打开。
(Defun vlxls-app-open(XLSFile UnHide / ExcelApp WorkSheet Sheets ActiveSheet Rtn)
  ;;;function: this program can open an excelfile
  (setq XLSFile (strcase XLSFile))
  (if (null (wcmatch XLSFile "*.XLS"))
  (setq XLSFile (strcat XLSFile ".XLS")))
  (if (and (findfile XLSFile)
       (setq Rtn (vlax-get-or-create-object "Excel.Application")))
    (progn (vlax-invoke-method (vlax-get-property Rtn 'WorkBooks)
        'Open XLSFile)
 (if UnHide
    (vla-put-visible Rtn 1)
    (vla-put-visible Rtn 0))))
  Rtn)
(setq *xlapp* (vlxls-app-open "C:/test.XLS"  nil))
(vlax-invoke-method *xlapp*  'QUIT) 关闭程序
GMT+8, 2025-5-21 23:50 , Processed in 0.234559 second(s), 27 queries , Gzip On.
