- ;*******************************刪除尺寸標注*******************************
复制代码- (defun C:dm(/ pickset)
- (Save-Set);;;保存初始设置
- (while(setq pickset(ssget '((0 . "DIMENSION"))))
- (if(/= nil pickset)
- (command "ERASE" pickset "")
- (princ "\n***未选取对象***")
- (Restore-Set);;;还原初始设置
- ;*******************************刪除文字*******************************
复制代码- (defun C:et(/ pickset)
- (while(setq pickset(ssget '((0 . "MTEXT,TEXT"))))
- ;*******************************刪除剖面線*******************************
复制代码- (defun C:eh(/ pickset)
- (while(setq pickset(ssget '((0 . "HATCH"))))
