查看: 4091|回复: 7
[求助]怎么将cad中的直线偏移一定距离
发表于 2009-5-9 15:10:00 | 显示全部楼层 |阅读模式
以下是源程序:程序的目的是在有各种图形的cad图中,把直线选出来,之后再将直线偏移一定的距离。 现在我可以选出直线,但是不知道该怎么偏移。请大家帮下忙~不盛感激。
Dim acadDoc As Object
Dim acadApp As Object
Private Sub CmdTj_Click()
    MsgBox "There are " & acadDoc.Layers.Count & " layer(s) in the drawing."
    MsgBox "There are " & acadDoc.ModelSpace.Count & " object(s) in ModelSpace."
    Dim objCount As Integer
    Dim I As Integer
    objCount = acadDoc.ModelSpace.Count
    Dim mspaceObj As AcadObject
    For I = 0 To objCount - 1
     Set mspaceObj = acadDoc.ModelSpace.Item(I)
      If mspaceObj.ObjectName = "AcDbLine" Then
         MsgBox "The objects in ModelSpace include: " & mspaceObj.ObjectName, vbInformation, "Count Example"
      End If
    Next
End Sub
Private Sub Form_Load()
Set acadApp = GetObject(, "AutoCAD.Application")
Set acadDoc = acadApp.ActiveDocument
End Sub
发表于 2009-5-9 15:22:00 | 显示全部楼层
Moves an object along a vector.
MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/move_see_also.htm">See Also | MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/ex_move.htm">Example
Signature
object.Move Point1, Point2
Object
MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/all_drawing_objects.htm">All Drawing Objects, MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_attributeref_object.htm">AttributeReference
The object or objects this method applies to.
Point1
Variant (three-element array of doubles); input-only
The 3D WCS coordinates specifying the first point of the move vector.
Point2
The 3D WCS coordinates specifying the second point of the move vector.
Remarks
The two points you specify define a displacement vector indicating how far the given object is to be moved and in what direction.
 楼主| 发表于 2009-5-9 22:17:00 | 显示全部楼层
谢谢了  但是没怎么看明白,能不能稍微详细的解释一下。或者在我的程序的基础上给出源代码呢?
 楼主| 发表于 2009-5-10 10:50:00 | 显示全部楼层
lzh741206发表于2009-5-9 15:22:00Moves an object along a vector.See Also | ExampleSignature object.Move Point1, Point2 ObjectAll Drawing Objects, AttributeReferenceThe object or objects this method applies to. Po
谢谢  但是你说的是move  我是问怎么offset?最好在我的程序基础上来点代码~~
发表于 2009-5-10 21:23:00 | 显示全部楼层
mspaceObj.offset(dist)
发表于 2009-5-14 19:13:00 | 显示全部楼层
  在前面加 Dim entobj As AcadEntity
在该语句后 MsgBox "The objects in ModelSpace include: " & mspaceObj.ObjectName, vbInformation, "Count Example"
        加 Set entobj = mspaceObj
        entobj.Offset (-5)
-5为偏移量
 楼主| 发表于 2009-5-16 10:53:00 | 显示全部楼层
已解决
发表于 2012-11-7 16:59:54 | 显示全部楼层
不知到沿着直线偏移文字怎么弄的
GMT+8, 2025-10-18 07:28 , Processed in 0.167715 second(s), 23 queries , Gzip On.
