查看: 1388|回复: 4
求助:这些代码生成DLL,无法调用
发表于 2009-5-21 11:28:00 | 显示全部楼层 |阅读模式
VBA代码:
Dim aa As New 工程1.Class1
Sub ff()
aa.xuexi3
End Sub
VB代码:
Option Explicit
Public Function addline(ByVal document As AcadDocument, ByVal ptSt As Variant, ByVal ptEn As Variant) As AcadLine
    Set addline = document.ModelSpace.addline(ptSt, ptEn)
End Function
Sub ABC()
On error resume next
Dim objline As AcadLine
Dim acadapp As AcadApplication
Dim acaddoc As AcadDocument
Set acaddoc = acadapp.ActiveDocument
Dim pt1(0 To 2) As Double, pt2(0 To 2) As Double
pt1(0) = 10: pt1(1) = 10: pt1(2) = 0
pt2(0) = 150: pt2(1) = 150: pt2(2) = 0
     Set objline = acaddoc.ModelSpace.addline(pt1, pt2)
objline.Update
End Sub
Sub xuexi3()
Dim acadapp As Object 'AcadApplication '
Dim acaddoc As Object
Set acadapp = GetObject(, "AutoCAD.Application")
acadapp.WindowState = acMax
Call ABC
End Sub
发表于 2009-5-21 12:32:00 | 显示全部楼层
应该把acadapp 、acaddoc 声明为模块级变量
 楼主| 发表于 2009-5-21 13:47:00 | 显示全部楼层
将两句提前
不行;改为
public acadapp As AcadApplication
public acaddoc As AcadDocument
也不行.
发表于 2009-5-21 14:07:00 | 显示全部楼层
Option Explicit
private acadapp As AcadApplication
Sub ABC()
Dim doc As AcadDocument
Set doc = acadapp.ActiveDocument
Set objline = doc.ModelSpace.addline(pt1, pt2)
End Sub
Sub xuexi3()
Call ABC
End Sub
 楼主| 发表于 2009-5-21 14:50:00 | 显示全部楼层
多谢板主,可以实现了,我的邮箱:sjsjgcl@163.com
GMT+8, 2025-4-30 21:36 , Processed in 0.176901 second(s), 23 queries , Gzip On.
