查看: 1777|回复: 5
(求救mccad)vb6可以调用ObjectDbx技术吗?
发表于 2009-5-22 19:03:00 | 显示全部楼层 |阅读模式
求救
vb6可以调用ObjectDbx技术实现不打开图纸进行文字查找替换吗?
               先谢了!
 楼主| 发表于 2009-5-22 21:00:00 | 显示全部楼层
这是源代码,希望mccad及高手修改下!!!
Option Explicit
Dim objDBX As Object
Private Sub Form_Activate()
If Left(Version, 2) = "15" Then
    Set objDBX = CreateObject("ObjectDBX.AxDbDocument.1")
End If
End Sub
Private Sub Command1_Click()
If ListView1.ListItems.Count = 0 Then
  MsgBox "请先选择图纸!"
 Exit Sub
Else
    Dim adText As AcadText
    Dim adMText As AcadMText
    Dim adSS As AcadSelectionSet
    Dim fType(0 To 1) As Integer, fData(0 To 1)
    Dim i As Integer
    If txtfind.Text = "" Or txtreplace.Text = "" Then
        MsgBox "输入所要替换的字符串内容!"
        Exit Sub
    End If
    Dim strFind As String
    Dim strReplace As String
    strFind = txtfind.Text
    strReplace = txtreplace.Text
    ' 打开图形进行操作
For i = 1 To Form1.ListView1.ListItems.Count + 1
Call ReplaceTextInDwg(Form1.ListView1.ListItems(i).SubItems(1) & "\" & ListView1.ListItems.Item(i), strFind,strReplace)
    Next i
End If
        MsgBox "OK!  ^_^"
End Sub
' 对某个图形进行文字替换
Private Sub ReplaceTextInDwg(ByVal strDwgName As String, ByVal strFind As String, _
                            ByVal strReplace As String)
    ' 打开指定的图形
objDBX.Open strDwgName
    Dim ent As AcadEntity
    For Each ent In objDBX.ModelSpace
        If TypeOf ent Is AcadText Or TypeOf ent Is AcadMText Then
            With ent
                If InStr(.TextString, strFind) Then .TextString = ReplaceStr(.TextString, strFind, strReplace, False)
            End With
        End If
    Next ent
    objDBX.SaveAs strDwgName
End Sub
' 对字符串中指定的字符进行替换
Public Function ReplaceStr(ByVal searchStr As String, ByVal oldStr As String, _
        ByVal newStr As String, ByVal firstOnly As Boolean) As String
    '对错误操作的处理
    If searchStr = "" Then Exit Function
    If oldStr = "" Then Exit Function
    ReplaceStr = ""
    Dim i As Integer, oldStrLen As Integer, holdStr As String, StrLoc As Integer
    '计算原来字符串的长度
    oldStrLen = Len(oldStr)
    StrLoc = InStr(searchStr, oldStr)
    While StrLoc > 0
        '获得图形中文字对象位于查找字符串之前的字符串
        holdStr = holdStr & Left(searchStr, StrLoc - 1) & newStr
        '获得文字对象位于查找字符串之后的字符串
        searchStr = Mid(searchStr, StrLoc + oldStrLen)
        If firstOnly Then ReplaceStr = holdStr & searchStr: Exit Function
    Wend
End Function
' 列表框中是否存在指定名称的项目
Private Function HasItem(ByVal strDwgName As String) As Boolean
    HasItem = False
    Dim i As Integer
        If StrComp(Form1.ListView1.ListItems(i).SubItems(1) & "\" & ListView1.ListItems.Item(i), strDwgName, vbTextCompare) = 0 Then
            HasItem = True
            Exit Function
        End If
    Next i
End Function
发表于 2009-5-22 21:09:00 | 显示全部楼层
ObjectDbx是在AutoCAD打开的基础上才能实现。请注意,它可以实现不打开图形而对图形进行操作,但需要打开AutoCAD。
如果在VB中,则可以打开AutoCAD并让AutoCAD隐藏起来的情况下进行操作。但这样的话,会有长时间停顿的问题,因为需要在后台打开AutoCAD。
 楼主| 发表于 2009-5-22 21:15:00 | 显示全部楼层
在VB中,可以实现不打开图形而对图形进行操作吗?
打开AutoCAD并让AutoCAD隐藏还是慢,可以像在ObjectDbx中那么快吗?
发表于 2009-5-22 21:30:00 | 显示全部楼层
Google 搜索 OpenDwg
 楼主| 发表于 2009-5-23 06:23:00 | 显示全部楼层
lzh741206发表于2009-5-22 21:30:00Google 搜索 OpenDwg
大哥,这个好像绝迹了,有谁能提供一下吗?不胜感激!
        ywwxmm@yeah.net
GMT+8, 2025-4-30 20:41 , Processed in 0.256572 second(s), 24 queries , Gzip On.
