查看: 2357|回复: 14
[求助]哪位高手帮忙看看这个程序错在了哪里?
发表于 2009-5-23 11:55:00 | 显示全部楼层 |阅读模式
;有很多这样的属性块,提示有“标高_1:10”、“标高_1:20”“标高_1:40”“标高_1:50”“标高_1:100”“标高_1:150”“标高_1:200”。。。
;下面这个程序是选择图中符合条件的块,然后进行缩放。
(Defun c:tt (/ DATA II OS SN SS STR)
(setq os (getvar "osmode"))
(setvar "osmode" 0)
(vlax-for BLK (vla-get-blocks
(vla-get-activedocument (vlax-get-acad-object))
(vlax-for X BLK
(if (and (= (vla-get-objectname X) "AcDbAttributeDefinition")
(wcmatch (setq str (vla-get-promptstring X))
"标高*"
(setq data (cons (cons (vla-get-name BLK)
(read (vl-string-subst
"标高_1:"
str
data
(foreach blk data
(if (setq ii -1
ss (ssget (list (cons 0 "insert") (cons 2 (car blk)))
(repeat (sslength ss)
(setq sn (ssname ss (setq ii (1+ ii))))
(command "_.Scale"
sn
(cdr (assoc 10 (entget sn)))
(/ 50.0 (cdr blk))
(setvar "osmode" os)
;哪位高手帮忙看看这个程序错在了哪里?附件中有测试文件。
发表于 2009-5-23 12:14:00 | 显示全部楼层
  1. (Defun c:tt (/ BNN DATA II OS SN SS STR)
  2.   (setq os (getvar "osmode"))
  3.   (setvar "osmode" 0)
  4.   (vlax-for BLK (vla-get-blocks
  5.     (vla-get-activedocument (vlax-get-acad-object))
  6.   )
  7.     (vlax-for X BLK
  8.       (if (and (= (vla-get-objectname X) "AcDbAttributeDefinition")
  9.         (wcmatch (setq str (vla-get-promptstring X))
  10.    "±ê¸ß*"
  11.         )
  12.    )
  13. (setq data (cons (cons (vla-get-name BLK)
  14.           (read (vl-string-subst
  15.            ""
  16.            "±ê¸ß_1:"
  17.            str
  18.          )
  19.           )
  20.     )
  21.     data
  22.      )
  23. )
  24.       )
  25.     )
  26.   )
  27.   (foreach blk data
  28.     (if (setq bnn (car blk)
  29.        bnn (if (= (substr bnn 1 1) "*")
  30.       (strcat "`" bnn)
  31.       bnn
  32.     )
  33.        ii  -1
  34.        ss  (ssget "_x"
  35.     (list (cons 0 "insert") (cons 2 bnn))
  36.     )
  37. )
  38.       (repeat (sslength ss)
  39. (setq sn (ssname ss (setq ii (1+ ii))))
  40. (command "_.Scale"
  41.    sn
  42.    ""
  43.    (cdr (assoc 10 (entget sn)))
  44.    (/ 50.0 (cdr blk))
  45. )
  46.       )
  47.     )
  48.   )
  49.   (setvar "osmode" os)
  50.   (princ)
  51. )
 楼主| 发表于 2009-5-23 12:51:00 | 显示全部楼层
非常感谢mmmmmm,但我想要的是:只对图中“所选择”的符合条件的块进行处理,并不是对图中“所有”符合条件的块进行处理。而且这个功能不要对图“所有块”进行判断,因为文件大一点的话就会很慢。
发表于 2009-5-23 20:49:00 | 显示全部楼层
  1. (Defun c:tt (/ BNN BNX DATA II OS SN SS STR)
  6.   )
  7.     (vlax-for X BLK
  10.    "标高*"
  11.         )
  12.    )
  15.            ""
  16.            "标高_1:"
  17.            str
  18.          )
  19.           )
  20.     )
  21.     data
  22.      )
  23. )
  24.       )
  25.     )
  26.   )
  28.     (setq bnn (car blk)
  31.   bnn
  32.        )
  33.     )
  34.     (if (null bnx)
  35.       (setq bnx bnn)
  36.       (setq bnx (strcat bnx "," bnn))
  37.     )
  38.   )
  39.   (if (and (princ "\n 请选择图块 <退出>:")
  40.     (setq ss (ssget (list (cons 0 "insert") (cons 2 bnn))))
  41.     (setq ii -1)
  42.       )
  43.     (repeat (sslength ss)
  44.       (setq sn (ssname ss (setq ii (1+ ii)))
  45.      scl (cdr (assoc (cdr (assoc 2 (entget sn))) data))
  46.       )
  47.       (command "_.Scale"
  48.         sn
  49.         ""
  50.         (cdr (assoc 10 (entget sn)))
  51.         (/ 50.0 scl)
  52.       )
  53.     )
  54.   )
  55.   (setvar "osmode" os)
  56.   (princ)
  57. )
 楼主| 发表于 2009-5-23 21:12:00 | 显示全部楼层
文件比较大时也是比较的慢,而且图中如果没有符合条件的属性块的话会出错:
命令: tt
 请选择图块 <退出>:; 错误: ssget 列表值错误
发表于 2009-5-24 00:25:00 | 显示全部楼层
要想速度快,你需要提高硬件。
图中如果没有符合条件的属性块,就不需要运行本程序,出错也无所谓。你自己也会一点点,可以自己去修改的。
 楼主| 发表于 2009-5-24 08:46:00 | 显示全部楼层
我有的是CPU酷瑞双核2.5G,内存2G,CAD2007.我这个程序是想对已有的选择集进行处理的。
(Defun c:tt ( / blk bnn bnx data ii scl sn ss ssi str)
(setq ss (ssget '((0 . "INSERT"))))
     (vla-get-activedocument (vla-get-objectname ss))
   );在此如何对已有选择对象SS进行判断呢?这里这样好像不行
     (vlax-for ss BLK
       (if (and (= (vla-get-objectname ss) "AcDbAttributeDefinition")
         (wcmatch (setq str (vla-get-promptstring ss))
    "标高*"
            "标高_1:"
            str
     data
   (foreach blk data
     (setq bnn (car blk)
   (strcat "`" bnn)
   bnn
     (if (null bnx)
       (setq bnx bnn)
   (if (and (/= nil bnn) (setq ii -1))
(vl-cmdf "select" ss "")
(setq ssi (ssget "p" (list (cons 0 "INSERT") (cons 2 bnn))))
     (repeat (sslength ssi)
       (setq sn (ssname ssi (setq ii (1+ ii)))
       (command "_.Scale"
         sn
         (/ 50.0 scl)
发表于 2009-5-24 09:17:00 | 显示全部楼层
 楼主| 发表于 2009-5-24 09:51:00 | 显示全部楼层
小萝卜头,你不明白我的意思,你的程序没能达到我想要的结果。
我想要的是:对已有选择对象SS进行判断呢?
 楼主| 发表于 2009-5-24 23:02:00 | 显示全部楼层
哪位高人出手帮忙一下,这将完成我的软件的一个阶段:
     (vlax-for ss BLK
    "标高*"
            "标高_1:"
            str
     data
   (foreach blk data
     (setq bnn (car blk)
   (strcat "`" bnn)
   bnn
     (if (null bnx)
       (setq bnx bnn)
       (command "_.Scale"
         sn
         (/ 50.0 scl)
GMT+8, 2025-2-25 02:37 , Processed in 0.205151 second(s), 28 queries , Gzip On.
