查看: 1189|回复: 0
为什么在cad中直接能填充,而vb编程却不行?
发表于 2009-5-24 09:51:00 | 显示全部楼层 |阅读模式
最近用vb编程画图发现同样是一个矩形框(全屏幕可见,闭合)用自定义的填充图案在cad 中用填充命令能填充上,而用vb编程却不能填充,小的矩形编程可以填充,一旦矩形上下长度超过某个值就填充不上,用cad自带的“ansi31”没有这种问题,由此判断是自定义填充图案的问题,后面有自定义填充图案,代码如下:
Private Sub Command1_Click()
Dim point0(3) As Double
Dim point1(3) As Double
Dim Acadapp As AcadApplication
On Error Resume Next
Set Acadapp = GetObject(, "AutoCAD.application")
If Err Then
   Err.Clear
   Set Acadapp = CreateObject("autocad.application")
If Err Then
   MsgBox ("不能运行AutoCAD")
   Exit Sub
   End If
End If
Acadapp.WindowState = acMax
Acadapp.Visible = True
Dim a As Single, b As Single
Dim lineobj As AcadLWPolyline
Dim points(0 To 9) As Double
Dim objlist(0) As AcadEntity
Dim objhatch As AcadHatch
a = Val(Text1.Text)  '矩形长
b = Val(Text2.Text)  '矩形宽,即高,将该值调高比如>20,即填充不上,这是为什么呢?
point0(0) = 0: point0(1) = 0: point0(2) = 0
point1(0) = a: point1(1) = b: point1(2) = 0
points(0) = 0: points(1) = 0
points(2) = points(0) + a: points(3) = points(1)
points(4) = points(2): points(5) = points(3) + b
points(6) = points(0): points(7) = points(5)
points(8) = 0: points(9) = 0
Set lineobj = Acadapp.ActiveDocument.ModelSpace.AddLightWeightPolyline(points)
Acadapp.ActiveDocument.ZoomWindow point0, point1
Set objhatch = Acadapp.ActiveDocument.ModelSpace.AddHatch(2, "s200", True, 0)
Set objlist(0) = lineobj
objhatch.AppendOuterLoop (objlist)
objhatch.Evaluate
ThisDrawing.Regen True
End Sub
附上自定义的填充图案"s200",这个自定义填充图案有什么问题呢?
GMT+8, 2025-11-7 01:42 , Processed in 0.175507 second(s), 25 queries , Gzip On.
