请教高手,这段程序为何修改不了?
(setq BLKS (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)) ) )(setq scal 20.0) (repeat (setq i (sslength ssi)) (setq sn (ssname ssi (setq i (1- i)))) (setq ELIST (entget sn)) (setq BLK_NA (cdr (assoc 2 ELIST))) (setq bb (cdr (assoc 1 (entget (entnext sn))))) (setq bb1 (strcat "1:" (rtos scal 2 0))) (vlax-for X (vla-item BLKS BLK_NA) (if (and (= (vla-get-objectname X) "AcDbAttributeDefinition") (wcmatch (vla-get-promptstring X) "图名_*") )(ZL-INSERT-SETATTVALUE sn bb bb1) ;修改属性块的属性值 ) ) )
你没有ZL-INSERT-SETATTVALUE函数的定义当然无法运行。
另外建议你先做些基本功课,了解块、属性等相关的知识,再来搞新的程序或者改写别人的程序。那样才能知道哪里要改,要不然好多时候会根本没有要领,自然无法真正提高。毕竟无法指望别人能帮你把所有程序写好。研究的精神可嘉,但要有好方法才能事半功倍。
这个函数是有的。
(defun ZL-INSERT-SETATTVALUE (EN ATTNAME VALUE / RETURN E TEST ENT) (setq E EN RETURN NIL TEST t ) (while (and TEST (setq E (entnext E)) ) (setq ENT (entget E)) (cond ;; ((not (= (cdr (assoc 0 ENT)) "ATTRIB")) (setq TEST NIL) ) ;; ((= "SEQEND" (cdr (assoc 0 ENT))) (setq TEST NIL) ) ;; ((= (cdr (assoc 2 ENT)) ATTNAME) (setq ENT (subst (cons 1 VALUE) (assoc 1 ENT) ENT ) ) (entmod ENT) (entupd EN) (setq RETURN t) ) ) ;_结束cond ) ;;返回 RETURN)
我有看了不少书呀。但还是一知半解的。
为何这样也不行:
(setq ii -1)(repeat (sslength ssi)(setq ent (ssname ssi (setq ii (1+ ii))) en (entget ent))(setq BLK_NA (cdr (assoc 2 en)));(setq bb (cdr (assoc 1 (entget (entnext ent)))))(setq bb1 (strcat "1:" (rtos scal 2 0)))(setq e1 (entget (entnext (cdr (car (entget ent))))))(vlax-for X (vla-item BLKS BLK_NA) (if (and (= (vla-get-objectname X) "AcDbAttributeDefinition") (wcmatch (vla-get-promptstring X) "海龙工具图名_*") )(progn (setq e1 (subst (cons 1 bb1) (assoc 1 e1) e1))(entmod e1)(entmod en) ) )))
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2024-9-29 18:20 , Processed in 0.177293 second(s), 26 queries , Gzip On.
